Android Marshmallow on RK3368 -> BOX64_v170117
Originally posted by clarkss12 View PostI have the Tronsmart R68 Meta, non-gigabit version.
Are you able to post your logs ..
adb shell dmesg
adb shell logcat
Pls post on pastebin.com .. And post the link here.
Maybe this can be fixed ...
And your original resource.IMG. where the 100mbit are working.
This would be a good "package" for further analysis
Cool . I will have a look .. what I directly saw .. your "small" resoucre.img .. seems to have no Logo included.
Will unpack and check ...
I just added my stock kernel.img if you need it.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
The X6 uses the AP6335 network with gig wired. The problems I had previous to your last build was no micro sd reader and if I unplug the OTG usb from my pc usb would not work at all.
Here are the specs -
Model
ZIDOO X6 Pro
Color
Silver
Shell Material
Environmentally friendly ABS
CPU Model
Rockchip RK3368 Octa Core up to 1.5GHz (Cortex-A53 64bit)
Operating System
Android 5.1, Built in Google Play Store,Support OTA Function
GPU
SGX6110; support 4K*2K H.265/H.264
Memory
2GB DDR3
Internal Storage
16GB eMMC
Wifi Connectivity
IEEE 802.11a/b/g/n, 802.11AC,4.900 GHz ~ 5.845 GHz (5.0 GHz ISM Band) AP6335 dual-band WIFI
Ethernet
1 * RJ-45 Ethernet Jack (10/100/1000Mbps)
Bluetooth
BT 4.0
HDMI Port
Standard HDMI female, v2.0 Support 4K@60fps Support HD Audio(7.1CH)
Other Interface
1 * TF card reader SD card interface . Support 1GB/2GB/4GB/8GB/16GB/32GB
2 * USB 2.0 port(one could be a OTG port)
1 * IR receiver
1 * Composite video and audio port
1 * S/SPDIF (2CH, 5.1CH)
Power
DC 5V/2A
What's in the box
1 x TV box
1 x Romote control
1 x HDMI cable
1 x Power adapter (EU/UK/US/AU)
1 x User manual
Video Format
DAT/MPEG/MPE/MPG/TS/TP/VOB/MP4/MOV/3GP/FLV/ISO/M2TS/BDISO/BDMV/WMV/WMA
Audio Format
DD/DD+/DTS /MP2/MP3/WMA/WAV/OGG /OGA/FLAC/ALAC/ APE/ AAC
[QUOTE=followmsi;n578319]Originally posted by DNIZoid View Post
Please use this kernel now .. for AP6330 .. Update.ZIP_Marshmallow_Kernel_AP6330_v160611.zip
To be installed via TWRP.
Guys I am sorry for all the noob questions but I am getting this error in TWRP. I would normally have a 2 gig internal SD card in my drives but I no longer do. I think when I loaded the dual boot image a few days ago I messed up my drives. Any help of getting it back?You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
[QUOTE=DNIZoid;n578368]Originally posted by followmsi View Post
Updated to new box version. Smooth and fast, with new kernal wifi still don't work, can't turn wifi on before new kernal wifi could be toggled on/off. Did factory wipe still no luck😟. Sd card not showing. Some good news usb is recognised in kodi so can access my media😆. M box the future. Keep up the good work. Thanks
Do factory reset afterwards as well ..
Thanks for testing !
There are currently 4282 users online. 0 members and 4282 guests.
