Android Marshmallow on RK3368 -> BOX64_v170117
Originally posted by mackjlm65 View PostI have a Zidoo X6 pro. It is on the latest stock firmware they just released last week. Is there something you need from the firmware or is there any testing I can do for you?
Right now, it s nothing to test .. But I will ask you again ..
I tried Beelink i68 firmware WiFi fix for AP6330 chipset by editing the numbers but did not work. On lonix firmware the work around fixed wifi issue. What wifi chipset is mm built on. The ap6330 kernel you made works but breaks the sd card and can't live without adaptive memory and is it possible for similar fix. Tryed fake wifi module from xposed but does not work on mm. Don't know when the dev will update for mmBeelink i68 firmware WiFi and Bluetooth fix for AP6330 chipset, BTW Zidoo v7 eliminated all of the stuttering as far as I can tell. Hardware : Beelink i68
Followmsi the only thing I found wrong with the Zidoo X6 was when you unplug the OTG cable you loose all USB. Even if you turn off the "connect to PC" in USB settings when you reboot its back on and no USB unless you turn off the "connect to PC" off again USB does not work. That really is the only issue on the Zidoo X6
Sd card is about the biggest improvement in marshmellow 64 bit a few programs exsist but none that would show how much better it is. I will say when video plays it does so very well on the mk68.... Ui seems alot slower then lollipop though and. Timed programs take about a few seconds longer to open in mm vers lp.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by DNIZoid View PostI tried Beelink i68 firmware WiFi fix for AP6330 chipset by editing the numbers but did not work. On lonix firmware the work around fixed wifi issue. What wifi chipset is mm built on. The ap6330 kernel you made works but breaks the sd card and can't live without adaptive memory and is it possible for similar fix. Tryed fake wifi module from xposed but does not work on mm. Don't know when the dev will update for mm
Maybe it's more easy to change sdcard on running wifi kernel ..
This are exactly the differenences between the boxes.
They just have the same cpu/gpu.
Yes, the Trick is changing config files on System.img.
We still have played on kernel level only.
The system.img is coming from geekbox sources, here they use the 6354 chip .. ac866 chip.
I think it's a variant of ap6335.
It's not planned to publish different System.img for all the different boxes.
But we may can fix it .. like you tried to change config .. etc. .. kind of hotfix for each Box.
Did you try stickmount for your sdcard already ?
Originally posted by mackjlm65 View PostFollowmsi the only thing I found wrong with the Zidoo X6 was when you unplug the OTG cable you loose all USB. Even if you turn off the "connect to PC" in USB settings when you reboot its back on and no USB unless you turn off the "connect to PC" off again USB does not work. That really is the only issue on the Zidoo X6
Thanks .. this is known .. maybe fixed soon.
The Problem seems to be on all boxes.
Originally posted by scooter2014 View PostSd card is about the biggest improvement in marshmellow 64 bit a few programs exsist but none that would show how much better it is. I will say when video plays it does so very well on the mk68.... Ui seems alot slower then lollipop though and. Timed programs take about a few seconds longer to open in mm vers lp.
Do you compare Android L and M ?
Is this new ? The slow ui ?
For me the ui is quite fast, still.
Actually I was hoping that more Box Reseller starting to work on mmallow .. releasing previews .. etc.
No single Box producer made any androidM preview, only geekbox.
they have all the same sources !
Once more people are working on mmallow, the quality will increase !
The Problem is related to the companies involved .. not with M
Running on N4 now .. real multiwindow .. etc.. just smooth !
On Nvidia tegra x1 .. not on Rk
Why is stock Kodi just work fine here ?
Believe me I would wish that it runs better and more people would help working on M.
Cheers
Originally posted by scooter2014 View PostDid you get the G logo? It worked on the mk68. First boot takes a long time. I had to erase flash on the second flash to get it working.
strange .. all these flash issues.
On geekbox flashing is so easy ... even with windows
Asking myself .. what is so different on the other RK3368 devices . ?
All the rockchip flash tools should work the same .. normally.
Have checked this webpage ... .as I guess the most people using windows tools ..
When you are at step 5 and load the new update.img .. does this tool show correct firmware version and loader version of the new firmware to be flashed ?
version 6.0.1
loader 2.53
Flashed on my Nexbox Z68 with no problem...used Android Tool 2.3....just Eraseflash before you upgrade rom...I flashed the AP6330 kernal...Was only able to connect with 3GHz wifi...5GHz not recognized at all....about 27,300 on Antutu Benchmarks..Thanx Followmsi for your efforts on providing with a 64 bit marshmallow rom...Is ethernet gigabit??....by the way the word ethernet is misspelled on the setting label..
There are currently 5263 users online. 1 members and 5262 guests.
