I would to replace my older buggy and impossible to use ekb328 by a new s905
I found 3 models
#MXQ pro+
#Beelink mini MXiii
#Mini M8S
It will used for iptv,x265 videos,and playing local videos via nas,
Important for me
A regular update (via ota is a plus)
A good network hardware (wifi n/ac & 1gb)
DRM gestion is a plus (for netflix in uhd)
Minimum passthroug problems
For 60$ max the shield is out the race,is the best for me but too expensive.
The pro+ just been launched and i scared for the support
Beelink have a community around but i dont know the network performance
the new Q box seems like a good candidate besure to get 2gb/16gb model has 1gb lan and dual wifi not sure on the support but comes with lollipop 5.1. I just got a m8s plus with the s812 soc also 1 gb lan dual wifi 16 gb storage new remote that actually works I dont do passthru so not sure on that but wifi performance has been great ap6330 wifi chip
One vote for Beelink M18 with openelec. Alu housing, 802.11a/b/g/n,2.4G+5.8G AP6330 wifi with external antenna, 2G/16G RAM/eMMC, bluetooth 4.0, 1000 MBit/s ethernet.
