Beelink Mini MX III hdmi passthrough sound stuttering with Kodi & SPMC
I didn't try through SPDIF, only through HDMI. As I discribed before, there is sound dropout (very short intermittent mutes) with DTS passthrough. This is very light but I cannot watch a movie with this problem.
I also downloaded Kodi 17 beta nightly build and the DTS problem is still there.
Notice that when you install this version, it will overwrite the Kodi preinstalled version.
I wanted to test the MINIX U1 (S905) XBMC modified version ... but installation is impossible due to Minix protection.
Well anyway I will try SPMC through SPDIF tonight and keep you posted.
Originally posted by nocturne View Postsorry, i closed it couse i tought it already solved, shoul it open it again? for me ac3 and DTS passthrough is ok with spdif using spmc 16.2
using spmc 16.2, no more clicking sound on aac., as for dts still have clicking sound but not all movie
Originally posted by chaminoux View PostHi
I just received the new Beelink Mini MX III today from Gearbest.
The box is small and nice and runs well.
The first thing I tried was movies through Kodi preinstalled with HDMI passthrough settings.
Unfortunately I have the same well known problem than some other boxes : DTS and AC3 movies sound stuttering / glitches every 10 seconds approximately.
MXQ / M8S+ / MXIII-Plus / Mini MX / Mini MXIII / T95 / Mini M8S II / R68 / V88 / GT1
With SPDIF output and SPMC 16.3.0 audio output passthrough => same problem.
I performed some more tests back to HDMI output and SPMC 16.3.0 audio output passthrough.
First I noticed that when you change audio output settings in SPMC, you’d better close SPMC and reboot the box before testing result. If you don’t, there is sometimes no audio at all after changing settings.
That said, box audio output set to HDMI, here are my results when changing parameters in SPMC 16.3.0:
* “Passthrough ouput device” set to “IEC passthrough”-> “Audio output device” set to “PCM”: AC3 dropouts; DTS dropouts* “Passthrough ouput device” set to “RAW passthrough”
-> “Audio output device” set to “IEC”: AC3 working; DTS dropouts
-> “Audio output device” set to “RAW”: AC3 working; DTS dropouts-> “Audio output device” set to “PCM”: no sound at all
-> “Audio output device” set to “IEC”: no sound at all
-> “Audio output device” set to “RAW”: no sound at all
So for now it's possible to have AC3 passthrough fully working, but not for DTS.
Can anyone try this Kodi version ( with the libmedia hack) and report back? thanks.
It is Kodi with passthrough enabled for the libmedia hack.
Originally posted by jmcm View Post
Hi, I just build the libmedia hack version of kodi16.1. Here it is
I'm looking for a new box now, because there are have lots HEVE h.265 video files appears. The Mini MX III looks good but I will wait and see until the passthrough issue get fixed.
Originally posted by nhan View Post
Hi, I tried it but there's no passthrough at all.
Waiting for Mi Box now( Not AD).
Xiaomi Mi Box (US) specifications:- SoC Amlogic S905X-H quad core ARM Cortex-A53 @ up to 2.0GHz with penta-core Mali-450MP GPU @ 750 MHz
- System Memory 2GB DDR3
- Storage 8GB eMMC flash
- Video Output HDMI 2.0a up to 4K @ 60 Hz with HDCP 2.2 and CEC support
- Audio Output HDMI, optical S/PDIF and 3.5mm audio jack
- Video Codecs VP9 Profile-2 & H.265 MP-10 up to 4K @ 60 fps, H.264 AVC up to 4K @ 30 fps, H.264 MVC up to 1080p60
- Audio Codecs DTS 2.0+ digital out, Dolby digital plus up to 7.1 pass-through
- HDR HDR10 and HLG HDR processing
- Connectivity 802.11 b/g/n/ac Wi-Fi and Bluetooth 4.0
- USB 1x USB 2.0 host ports
- DRM Widevine L1 + PlayReady 3.0
Mi Box supports both Dolby Digital Plus and DTS multichannel HD audio encoding.
The result is smoother, dynamic, immersive and more realistic stereo surround
sound during ultra HD Blu-ray video playback.
Anyway nice box, but how will play high bitrate content without Ethernet jack?
There are currently 1906 users online. 3 members and 1903 guests.
