Nexbox – Z68, Zidoo X6 pro edition by STZO
    Hi Guys,
    I create this new topic to add a new, alternative replacement to the unusable stock firmware of the Z68 TV box sold by Geekbuying. Similar to other variants, this one also may have pros and cons, but as a media box, it provides the widest range of services and features I experienced by now. This ROM was composed mainly from parts of other published firmwares, with adding some modifications on them to have it run better on the Z68 specific hardware. Unfortunately, the hardware (as it comes from the factory) has some weakness, mainly as the processor cooling is concerned. In order to have a reliable device, you must have to install an appropriate heat-sink onto the SoC. A possible solution you can see on this photo:
    The system basics come from the Zidoo X6 pro software modified and published by lonix, hardware support added by STZO, and also the boot logos and animation were replaced as the label of the composer. This is version #5.1 already, to provide you with a well tested solution.
    What's working perfectly:
    - 2,4 and 5GHz wifi
    - gigabit LAN
    - functional IR remote (except Mute, but with an alternative keyboard layout added)
    - auto-framerate changing (please copy advancedsettings.xml into the userdata directory)
    - HDMI audio passthrough (DTS, Dolby Digital)
    - 5.1 audio transcoding (please do not forget to set „Keep audio alive" = Never)
    - blue LED when operated (near zero power consumption only when it lights in Red)
    - 0,1-0,2W standby power consumption (no need of power off!)
    - TWRP recovery installed
    - lifetime license
    Not tested by me:
    - USB HDD support
    - bluetooth headphone support
    - HD audio passthrough (DTS-HD, DolbyDigital Plus etc.; I have no such device, please report results!)
    Remaining issues:
    - no power off function (this is a Z86 hardware specific feature, but it's not necessary either)
    - 7.1 HD audio (different formats) to Dolby Digital transcoding in KODI don't work, should be changed back to stereo to get sound from 7.1 audios.
    - some Zidoo apps may not work (not accurately tested)
    - MAC address' (IP numbers) are changing at every boot-up (it can finally be solved with this tool: UpgradeDllTool_Release_v1.35: https://mega.nz/#!XplFzSCR!CRV8zYNZ5...M3465prlCtRnDc )
    Actually, most of you could be satisfied with this ROM. For proper audio transcoding operation in KODI, must „Keep audio alive” option turned off („Never”). Stereo sound is always perfect even if the material contains 7.1 audio. Movies with DTS or DolbyDigital sound will be played perfectly, but sometimes 'jumping' in time during playback can have problem with DD sound. For the best result, plase copy the Advancedsettings.xml file from the system/preinstall/kodi into the Android/data/org.xmbc.kodi/files/.kodi/userdata directory, it will enhance the correct framerate recognition!
    Link to the ROM:
    Install hints:
    At the first powering after the upgrade, it will automatically reboot. Following the reboot, the fist run takes approx 5 minutes to install the applications before is stands up. Since that time you can enjoy all the functionalities. Please be patient during the boot animation at the first run, it lasts about 5 minutes (apps are installed). Later it boots up in approx. 20 seconds.
    Most of the preinstalled applications you can easily remove if do not want to use them.
    I included 3 different resource images with 2 different IR remote key layouts. V1 is integrated into the rom package, it realizes the factoy functions, except that the Mute button takes you to the previous applications menu. With V11, the Mute button functions as Menu, and the Menu button has the same funtion as of the Back. This is my favorite arrangement, as it ensures the best fail-safe control any time. V31 is almost the same as V1 with the factory remote, maybe other remotes operate differently with it.
    ROM is rooted. AnTuTu benchmark is 30-32000. LAN speed is 90Mbit up, 180 Mbit down, wifi speed is 12Mbit up, 18Mbit down at 5GHz (2,4 GHz is similar), measured with 32kB packet sizes. Audio lag in DTS and DD movies is approx. 0,3 sec. Wifi speed test results you may see on this screenshot here:
    I also tried this addon in KODI:
    plugin.video.youtube-master
    https://mega.nz/#!qhVFnJ7K!JFuBJWkYR...pAVOOoZU_Q8N-8
    this is the first way of getting auto-framerate changes when playing YouTube videos that I found. Works perfectly!
    Additional information:
    Maybe you need to wipe the storage before flashing! (It ensures that no junk remains in the empty spaces, which could make trouble if getting a call accidentally.) Use Android Tool to do that:
    https://mega.nz/#!X5M1CQ4S!a__lJtR0q...VXSgapu7RV-Ly0
    When using Android tool to download img files, for separate file downloads please use this (or equivalent) config file (enclosed with the above package too) in Android Tool:
    https://mega.nz/#!HtdniJ5A!vMhZM8oox...6gY1ejSOSdsJAs
    Image file names and locations should be set to the actual ones, or select them by clicking on the "..." cell of the table.
    Good luck with best regards, STZO
    Regards, STZO
    Very nice! I will try this one soon!
    ps: What is the item "- lifetime license"?
    kind regards
    cyber7 (aka Aubrey Kloppers; Cape Town; South Africa)
    http://www.cyber7.co.za / http://aubreykloppers.wordpress.com
      As I wrote before:
      Runnig Zidoo ROM on any hardware other than Zidoo, a big white nag window pops up in every minutes ("Illegal Activation message), which makes the device unusable. Early Lonix roms block the IP numbers that the rom attempts to connect. It works until Zidoo changes this IP number. Zidoo has new IP numbers in every 3-6 months, so the new IP number should be entered into the blocked list of numbers every time again. This is what I eliminated in my package.
      Regards, STZO
        Hi STZO,
        Where can I find the advancedsettings.xml file as you posted?
        Thank you,
          Hello STZO, does this Zidoo ROM support multi-user accounts? I am running your Nagracev4 rom (which does) and I didn't want to overwrite everything to find out the answer? (actually I am awaiting a real Zidoo X6 Pro box in the mail so it would be nice to share the UI etc. for Z68 also). Thanks Daximus
            Hi STZO,
            Thank you,
            In the Root/System/Preinstall/kodi directory. You can copy the file with Total comander very easy. You may check the file properties after the copy, it's access rights should be 660.
            Regards, STZO
              Yes, it supports that, at least in the setting menu you can add new users and/or profiles. Anyway, I used the Nagrace based firmware for a while, but did not hesitate to replace it to the Zidoo based one. It's much better! I especially like the background wallpaper of the integrated Launcher3 apk: it's a black floor with tile grids in a perspective, where some tiles are dropped down making holes in the floor.
              Yes, creating the new settings (personalize the device) is always a big problem when replacing the ROM. This is my final solution, I'll make changes only in the installed vesion if necessary, will never be replaced the complete rom to another one.
              Regards, STZO
                Couple of questions,
                Do I install this like the other ones, via a male to male USB cable, and using the Rockchip tool?
                Also, is the launcher the same as the ones I see for the original Zidoo X6 pro? (pictured below) If I don't like this, can I go back to another version of firmware?
                  https://images-na.ssl-images-amazon....L._SL1000_.jpg
                  I used Android tool to flash, but I cannot see any reason why you couldn't do it with other Rockchip flash tools. All informations included with the package to do that.
                  The screenshot you cited is of the zidoo Launcher, you can easily change it to any other launcher if you want. My favourite is this one (included too):
                  Regards, STZO
                    Hi Stzo,
                    Thank you for your time.
                    Regards,
                    KN
                      having issues connecting to playstore with this firmware.
                        Do you mean Google Play? What problem do you experience? I avoid to connect Google account, as many apps will attempt to update, which could break the existing applications run.
                        Regards, STZO
                          Yes. I see error saying cannot connect to Google play store.
                              Hi Guys,
                              Thanks for the report about the Google Play issue! This is not the first time that Google makes a trouble itself, and I'm not sure this is unintentional!
                              Here is another link:
                              Regards, STZO
