Step by Step Instructions on How to Install Openelec on MXQ Pro+ Dual Boot Via SD Card
Hi Doggyofone, will this how-to work with a MXQ PRO+ 4k based on amlogic S905 - http://www.geekbuying.com/item/MXQ-P...-0-366249.html ? Thanks
Originally posted by LittleJ View PostHi Doggyofone, will this how-to work with a MXQ PRO+ 4k based on amlogic S905 - http://www.geekbuying.com/item/MXQ-P...-0-366249.html ? ThanksI believe that if life gives you lemons, you should make lemonade... And try to find somebody whose life has given them vodka, and have a party.
Ron White
The best way to make sure is to read your way through the many posts on this site and soak up the knowledge. There is tons of great information within these forums and many other forums that are linked in the posts, or can be found via Google. This method is is for an sd dual boot system. If you follow the instructions you won't brick anything. OpenELEC will run off the SD card and will not impact Android. You want Android, pull the SD and reboot.
Did you read your way through the original post yet? Openelec for Tronsmart Vega S95 - FreakTab.comI believe that if life gives you lemons, you should make lemonade... And try to find somebody whose life has given them vodka, and have a party.
Ron White
Originally posted by seibalo View PostThanks doggyofone, very good guide.
I follow your instructions, the box works well now.
But the remote don't work on openelec, it's that the same for you?
You can get into OE sd card via windows explorer. To do so you need to install these drivers: http://www.ext2fsd.com/. You open windows explorer, type in the IP for the box like this \\yourboxIP\. Open config files and copy paste remote.conf. Reboot the box and your remote will work. The key functions take some getting used to.
Check the posts on the last page of this post Openelec for Tronsmart Vega S95 - FreakTab.comThe former Doggyofone
Originally posted by ioadam01 View PostHi guys.
Sorry for asking, but are there any possibility to run OE on mk808b pro? I'm not asking you to try it, I'm just wondering if this is technically possible.
If yes, I will try and let you know. Sorry for bad knowledge, I'm new in this context
Read up at this forum - kszaq's LE ForumI believe that if life gives you lemons, you should make lemonade... And try to find somebody whose life has given them vodka, and have a party.
Ron White
There are currently 2667 users online. 1 members and 2666 guests.
