Step by Step Instructions on How to Install Openelec on MXQ Pro+ Dual Boot Via SD Card
I would like to put on the aml auoscript from the update_uboot/mxq pro plus directory on the link. I copy the zip into an sdcard, select it in "update and backup" app, pushing update. After reboot, the bootloader say unknown footer chacksum or just nothing happens with black screen.
Have somebody got a working aml_autoscript for this device? I would like to try out ubuntu.
Originally posted by Teddybee View PostI would like to put on the aml auoscript from the update_uboot/mxq pro plus directory on the link. I copy the zip into an sdcard, select it in "update and backup" app, pushing update. After reboot, the bootloader say unknown footer chacksum or just nothing happens with black screen.
Have somebody got a working aml_autoscript for this device? I would like to try out ubuntu.I believe that if life gives you lemons, you should make lemonade... And try to find somebody whose life has given them vodka, and have a party.
Ron White
Hi, Installed this and worked fine, having 1 issue with network, won't connect to network as wireless is not present, and when I connect with wired connection does not pick up a valid IP from my network. Set it to manual and added IP manually but still won't connect. Strange thing is that when on dhcp it does pick an IP up but not in my network range. Does the image have any settings for VPN included?
I have not done this yet on my S905 MXQ Pro Android 5.1.1 OTT TV Box, yet. I want to know if openelec you all installed used on your device does come with a GUI and some (Libre) Office software. I want to use mine with my 42" LED HDMI TV as a Linux desktop computer to do some office works + as a TV Box using kodi.
Originally posted by cunnifa View PostHi, Installed this and worked fine, having 1 issue with network, won't connect to network as wireless is not present, and when I connect with wired connection does not pick up a valid IP from my network. Set it to manual and added IP manually but still won't connect. Strange thing is that when on dhcp it does pick an IP up but not in my network range. Does the image have any settings for VPN included?
It does have VPN. Here's a good addon for OE to manage VPN - OpenELEC openvpn manager
You should also check this thread and the update to Libreelec - Openelec for Tronsmart Vega S95 - FreakTab.com
Ron White
Originally posted by Habibie View PostI have not done this yet on my S905 MXQ Pro Android 5.1.1 OTT TV Box, yet. I want to know if openelec you all installed used on your device does come with a GUI and some (Libre) Office software. I want to use mine with my 42" LED HDMI TV as a Linux desktop computer to do some office works + as a TV Box using kodi.I believe that if life gives you lemons, you should make lemonade... And try to find somebody whose life has given them vodka, and have a party.
Ron White
Originally posted by Habibie View PostMine is MXQ Pro and not MXQ Pro+. I may be wrong, but AFAICT the difference between the two is the amount of RAM/eMMC storage, i.e. same CPU, etc. Regardless, I want to know if Openelec has a support for GUI (out of the box) to include some (Libre) office packages.I believe that if life gives you lemons, you should make lemonade... And try to find somebody whose life has given them vodka, and have a party.
Ron White
Originally posted by Doggyofone View Post
Try this link and check page 28 to the end. Balbes 150 has posted a new img for LE for this box..Openelec for Tronsmart Vega S95 - FreakTab.com
Link
P.S.: I can't shut down the box and can't update it to the latest LE beta 7.90.005. (I tried the odroid-c2 update tar)Last edited by Teddybee; 03 September 2016, 17:58.
There are currently 2523 users online. 0 members and 2523 guests.
