Official Android 4.2 for MK802 III
    ok unpacked succesfully the image.
    let's mod it now.
    see you back in a houre ok ?
    if you love my work please buy a coffee
    <form action="https://www.paypal.com/cgi-bin/webscr" method="post">https://www.paypalobjects.com/en_GB/i/scr/pixel.gif
    </form>
      let's mod it now.
      Yeah I'm here ready all night
        Re: Official Android 4.2 for MK802 III
        Ok rom is uploading now
        Stay tuned
        Verstuurd van mijn GT-S5660 met Tapatalk
        </form>
          Stay tuned
          ok here it is.
          please flash everything.
          if wiffi always not works after a reboot , then flash just finless 1.8 kernel without erasing idb.
          JUST FLASH KERNEL.
          reboot and look if wiffi works then.
          but first flash my whole package first with erasing idb.
          looks if it boots and wiffi works.
          </form>
            ok here it is.
            JUST FLASH KERNEL.
            Wifi still didn't work, also tried after a reboot.
            After that I tried flashing the kernel, without much luck. It produced a lot of artifacts on my screen, hard crash etc. :/
            Also, when flashing the kernel it did ask for loader, I tried with your loader and not the finless one.
            Parameter file was missing from your test rom, hence I tried both the preexisting 4gb and the old one from your rom.
              ok no problem im busy with the original rom now.
              sow wifi will work 10000% now.
              im almost ready.
              stay tuned.
              </form>
                Okay nice!
                I suggest putting 720p as default resolution, yours had 1080p I believe, and it caused some problems in the start as my TV doesn't support it.
                  Okay nice!
                  the kernel and boot are the 720p version from finless.
                  ok im uploading it again.
                  wifi must work now .
                  if not than you got another stick or you give me a wrong link.
                  i just added my apps and extras and changed the build.prop.
                  the ui mod i didn't
                  first see if this works.
                  the parameter is included now.
                  </form>
                    ok here it is
                    this is the original version from the link you give me.
                    i maked the system.img larger for adding stuff.
                    you have 3 launchers now for choosing.
                    looks if you get root permissions also now .
                    the app storage is now 2 gig standard.
                    added tweaks to build.prop also.
                    </form>
                      ok here it is
                      I just installed it, still no wifi support I'm afraid :/ I tried rebooting the system 3 times to confirm it. Just to clarify, the wifi worked just fine with the original you modified.
                        So this one works now .right?
                        </form>
                          No, it doesn't :/
                            So the original modded rom has no working wiffi?
                            </form>
                              No, it doesn't.
                              The original (un-modded) did have a working wifi though.
                                Ok i start tomorrow evening again.
                                </form>
