Official Android 4.2 for MK802 III
Originally posted by Trollgeir View PostAlright! Well keep up the good work
download this.
this are the original files from the stock rom.
open my last romkit.
go to the snakerom folder and replace the kernel.img with the original .
look if it flash succesfull.
if you have a download check faill then you must replace the parameter file also with the one from the stock rom.
the problem for the wifi is the kernel that i took from finless with this stick.
so normally it must work now with my modded stock romLast edited by snakekiller; 23 June 2013, 23:02.if you love my work please buy a coffee
<form action="https://www.paypal.com/cgi-bin/webscr" method="post">https://www.paypalobjects.com/en_GB/i/scr/pixel.gif
</form>
Hi.
I'm not sure if my minipc is the 802III but the case says AK-802 and it has bluetooth, headphone connector, and a reset conector near HDMI port.
I've tried your last rom and it works ok but I don't have bluetooth neither wifi, the wifi does nothing.
My wifi/bluetooth chip is a RK903.
Uhost U2 - RK903 (BCM40183 - Broadcom 4330 Based Chipset) (Bluetooth v3.0)
MK808B - RK903 (BCM40183 - Broadcom 4330 Based Chipset) (Bluetooth v3.0)
Minix Neo X5 - RK903 (BCM40183 - Broadcom 4330 Based Chipset) (Bluetooth v3.0)
I recommend trying to look for roms based on those models, this one isn't for your device.
Wifi doesn't work
Hello,
I bought 5 mk802IIIs Rikomagic and they all have 4.2.2 onboard.
Because of the high resolution of them I decided to downgrade the firmware to 4.1.
Everything goes well except for the wifi. It doesn't work.
I tried every possibile stock and custom ROM but wifi still doesn't work. I reflash the 4.2.2 custom ROM but it's all the same.
Should I take some wifi files from the others devices and copy them on the corrupt one?
Help please!!!
You proberly have the new version with AP6210 wifi/BTchip so the normal stock FW is not working for You.
Look in the thred: http://www.freaktab.com/showthread.p...ll=1#post98881
RM have 2 dowload links first the AP6210 and secund is for the normal old ones.
I think it no 4.1 FW for the AP6210 but You can always puting down the HDMI to 720P and You geting more CPU for the appsMK802IIIS/BT
Originally posted by MattWest View PostYou proberly have the new version with AP6210 wifi/BTchip so the normal stock FW is not working for You.
Even if I put 720P I notice no differences on the screenand this is an important characteristic for me!
I'm going to install this Finless 2.1 ROM http://www.freaktab.com/showthread.p...l=1#post100755
Hope to solve it!
Thank you
Originally posted by Flegias View PostEven if I put 720P I notice no differences on the screenand this is an important characteristic for me!
1. Open Root Explorer.
2. Go to /system
3. Click on Mount RW (It should appear as Mount RO, that’s when it is correct!)
4. Look for build.prop. Long press on the file and press Open file in Editor
5. Scroll down to ro.sf.lcd_density=160
6. Change the value to 200 (or another). The lower the value, the higher density your screen will have.
7. Click on the Menu button, and Save and Exit.
8. Reboot.
Try to do it. You will have 1080p look like 720p.
There are currently 1516 users online. 0 members and 1516 guests.
