Thank you
Q-Box updated firmware
Originally posted by jbond View Post
Yes....can anyone confirm if this legit?
This q-box (16g/2g) firmware runs like perfect, but the Generic.kl (KeyMap) for external keyboard (via Bluetooth or usb) is on the button "Enter" wrong. You should change it manually.
key 28 should be "key 28 ENTER".
Originally posted by Stahldroid View Post
http://blog.geekbuying.com/index.php...ware-20160614/ Uploaded on 20170121
As Found: QBOX_905_216_QB0006
Not sure of Version not tested
Q-BOX 4K KODI AMLOGIC S905 2GB/16GB TV BOX FIRMWARE UPDATE 20170915
2GB/16GB PC Flash Firmware
Flash guide, please refer to: http://blog.geekbuying.com/index.php...utorials-tool/
Source Blog.geekbuying
Hello, First-time poster. I would like to update my firmware, but everything I've read tells me to use the zip file on my sd card or usb stick. The problem is that the new firmwares are .img files. How do I get the box to read the .img file after a hard reset with my sd card in the slot or the usb stick in the usb slot?
Originally posted by caseythebeagle View PostHello, First-time poster. I would like to update my firmware, but everything I've read tells me to use the zip file on my sd card or usb stick. The problem is that the new firmwares are .img files. How do I get the box to read the .img file after a hard reset with my sd card in the slot or the usb stick in the usb slot?
You will need to flash it with a pc using the USB burning tool,Flash guide, please refer to
http://blog.geekbuying.com/2016/02/a...utorials-tool/
Edit: Iv just made a quick video to show you the pc flashing using the USB burning tool
Last edited by blinkone; 19 November 2017, 14:45.Please consider making a Donation to freakTab
Originally posted by caseythebeagle View PostBlink bone, However the video you posted seems to be an ms8 review, not a tutorial to flash the box using pm and the burning tool.
would you please post again or post the link.
thanks
Originally posted by caseythebeagle View PostBlinkone, I will need to create/buy a male to male usb.
Keep it short(0.5mtr or less) is supposedly better.
There are currently 2130 users online. 1 members and 2129 guests.
