Running OPENLEC from EXT media & installation of TWRP
    Ok, the device is alive again, I bought me a sandisk Ultra, but again no WIFI??? I can 't enable WIFI, why???
    Many thanks for your patience @desmondo!
      Did you definitely copy over your dtb file. Once you burned the disc. I believe the openelec is for the tronsmart and when I tried that long ago there was no wifi. This may have been fixed by now by balbes. But the dtb file acts I believe like the driver disc. Which firmware did you put on in android? Was it the latest on this site? If it is be sure to extract the dtb file and transfer to sd after burning and overwrite the generic one.
        No dear desmondo, I 'm talking about android, not OpenElec, when I go to networks => wifi device => on or off, I can 't choose ON!
          I realise that but which android firmware did you use? You need the dtb file from that firmware and is the wifi working on the android side?
            Perhaps the 8gb version uses different wifi chip?
              I used the firmware from the .rar with bootcard maker, OpenElec is not running, I 'm trying android first and it is there that wifi not is running, I 've read somthing about deleting wpa_supplicant.conf as a solution?
                hmmm, Where should I could find 8GB stock-firmware?
                  Damm chinese vendors, I bought 16GB, but they send me only 8GB
                    I would update firmware to the one on this site posted a few days ago. Then extract dtb and keep hold of it and re burn the OE and replace the the dtb. See if that solves it if not you are probably looking at different hardware.
                      Where did you get the dtb file from for the firmware as one included with the oe is for tronsmart. It is very important that you burn the oe and then replaced the dtb on the sd card with the one from the latest firmware on this site.
                        I know, I think the firmware for 8GB is slightly different as for 16Gb version...
                          It might be but the firmware is compatible I believe with both now. So just use it and check if wifi works on android if so proceed to burn card.
                            I did this already yesterday and lost wifi, I will try again later
                              Negative, even with the latest firm QBOX-0610-zip.zip no WIFI, there is a difference for sure between 8GB and 16GB, my problem is that I can 't find any support for my version, same issue here; http://freaktab.com/forum/tv-player-...art-s89/page46
                                Maybe is difference is is this one you sad using
