regards.
Running OPENLEC from EXT media & installation of TWRP
Hi, like I said wifi is working again,Originally posted by Jefken3 View PostOriginally posted by Jefken3 View Post
regards.Last edited by Jefken3; 19 June 2016, 05:55.
Originally posted by balbes150 View Post
Show the contents of your remot.conf. Need to replace the code that "OK" (perhaps now 97). For code 28.
Originally posted by Jefken3 View PostHelp! I 've think I have bricked my device, reflashd, but recovery appeard and was gone, now nothing is happening annymore, any advice!Last edited by carianis; 25 June 2016, 12:10.
Originally posted by balbes150 View PostHi desmondo I don't quite understand what it was about. (I use a computer translator).
Originally posted by balbes150 View PostI have a set-top box and remote control, as You have. So I will not be able to perform analysis of the ...
1. Android uses a different set of correspondences of codes of actions for the remote control. The table of correspondence of action and codes in Android is different from OE. For example, as the "Ok" button. In Android code 97, and 28 OE. You also need to consider that the functions of the processing codes may be different or absent.
2. Do I understand correctly that You want to try to install OE in the internal memory ?
Originally posted by balbes150 View PostNeed file remote to add to the installed system. It can be changed by selecting the working state. The main problem is the installation of OE to internal memory - a working dtb file. What would the system normally started.
The correct file for the remote control can be loaded into a running system. To obtain a working system OE necessarily need a dtb file. Without a valid dtb file the system will not boot. Therefore, what would be the correct dtb file would always be included as part of your image to record to the internal memory. File to the remote control unit can be replaced later on a running system using the connected keyboard and mouse.
Hello boys, I have a problem, I don't understand what I do about this step:
Originally posted by desmondo View Post
Openelec downloads
Download one of the images made available by balbes15O, I used 6.95.3 and place in a folder extract the zip file until you have OE image.
There are currently 4264 users online. 1 members and 4263 guests.
