Minix Neo U1 firmware port for MiniMXIII
    Based on latest Minix Firmware NEO U1 FW009 - 20160804
    Change log since FW008:
    1.) Enhanced video deinterlacer quality
    2.) Fixed a HDMI-CEC bug
    3.) Size of mouse cursor doubled
    4.) Updated MINIX XBMC app (requires manual update)*
    5.) Fixed a MINIX UI bug
    Can confirm HD audio passthrough working flawlessly with SPMC, no drops!
    Firmware (IMG) : https://yadi.sk/d/wUYsl16RuBPQA
    Flash with burning tool (howto) : https://yadi.sk/d/nXet80FQsmF4n/
    Source: 4pda
    Minix U1 EZ root ZIP method (working): http://freaktab.com/forum/tv-player-...oot-zip-method
    Is there a way to make it work with Beelink Mini MX?
      Is this rooted? (I want a MiniMXIII ROM I can run Xposed framework on). ThankS!
        No but you can root it easily
          Updated to FW009 - 20160804
            anyone know if this can play udp streams(iptv streams) on kodi without the buffering bug?
              Thank for the work.
              Can you confirm if it will work on a Beelink Minimxiii?
              Do wifi and Bluetooth work?
              Any known issues?
                Hi Guys, Thanks for this... this is awesome. What happens with regards to updates? Can one do automatic updates with this rom, or does one always have to flash with the latest rom manually?
                Thanks for the great work.
                  Hi, i'm a noob i have to burn SD with img file and Win32DiskImager ?
                  Thankyou
                    Hi.
                    Dommels is wi-fi working?
                    I'm concerned because there are major differences betwen the two boxes [in this area]??!!
                    N
                      Originally posted by nifedipin View Post
                      Hi.
                      N
                      Hmm it doesn't . It used to work in the previous rom (W008: https://yadi.sk/d/WE_chvQbskJ6y)
                      But now it starts connecting to the wifi (obtaining ip address) and immediately disconnects
                      I didn't pay attention because previous firmware worked and I'm using ethernet. Can confirm bluetooth still working.
                      edit: I've seen speedtests on the Russian forum with this firmware so it must be my setup
                        Dommels,
                        I'm very interestred...could you find out FOR SURE what is the problem with wi-fi??
                        More:
                        1.Is DTS-MA and DOLBY TRUEHD passthrough working?
                        2.Can you play 3D ISO BR.???
                          I will test the wifi some more.
                          I can confirm HD audio passthrough is working flawlessly with SPMC.
                          UPDATE: WiFi works! After disabling LAN my wifi started working.
                          3D ISO BR = no problem (Kodi sample)
                            Hi everyone !
                            Can someone confirm, or not, that dynamic refresh rate switching works in Kodi/SPMC with this rom ?
                              Dommels....you have a P.M.
                              N
