Usb burn tool 2.0.7.
Originally posted by vostro View Posti tried this 2.0.8 but this tool like previous version, can't make my tv boxes visible(TX5 Pro and A95X), i.e. it never shows up in device, any solution for this?Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
hmm that is what i have. I did install before anniversary update. Does it ding when you plug it in? It should show up. Maybe bad usb cable. On the tanix it is the usb port closest to the pin hole on the bottom. Device should power on when usb is connected.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by vostro View Postwithout external power, box does power up with USB cable connected, that means cable is ok, but there is no sound from windows when i connect this box with USB cable, so i doubt if driver functioning well.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
I've had no luck getting the MINI M8S II to accept the Frankenfirm. I can get the box to connect and I've tried, I believe every permutation of loading the image and so on but the firmware erase always fails with an error code.
To the person that can't get the box to even recognize the box? That can happen. Try different USB ports. Try uninstalling the tool then re-installing. Try a different version then re-installing the latest one. At some point, it should connect. It's frustrating to say the least. I've spent about six or seven hours over two days trying to get this to go and no luck. I did get the customization tool going and managed to figure out how to move the remote files and re-pack and then unpack again for insurance. I've read pretty much every post going on this, including the now 33 pages main thread.
Apologies if this isn't the right place to post....but, grrrrr. Oh, and hi everyone, these boxes are a cheap and cheerful things to fool around with, eh? I got into this because the audio passthrough doesn't work without dropouts (ac3/dts) and the SPDIF doesn't work at all. So annoying I don't even want to watch anything on it since, well, two channel is sooo barbaric, lol.
Originally posted by Cadsmote View PostTry different USB ports..
Originally posted by Cadsmote View PostTry uninstalling the tool then re-installing.
Originally posted by Cadsmote View PostTry a different version then re-installing the latest one.
Originally posted by Cadsmote View PostAt some point, it should connect. .
Originally posted by vostro View Postyes, tried each available USB port, no luck.
yes, tried many time, no luck.
yes, tried 2.0.5, 2.0.5.15, 2.0.7, 2.0.8, nothing works.
this is still a dream to me.
There are currently 2068 users online. 1 members and 2067 guests.
