You will have to do it over WiFi
Usb burn tool 2.0.7.
Hello,
sorry for updating this thread but I have the feeling someone could help me here.
I have a mini m8s II, and bricked it trying to install Android TV on it (SD card method).
Now if I try to reinstall the default firmware (http://chinagadgetsreviews.com/downl...-tv-box-3.html) using the SD Card method, but it gets stuck on the default "Upgrading..." black screen with the ugly droid. xD
So I tried to use the USB Burning tool method (v2.0.8), when I plug my box on the computer it's automatically detected by USB Burning Tool, and the flash process starts normally.
But when the process reach 7% at the "formatting..." phase, I always the same error.
Here is the entire log : (The error is bellow -------------ERASE FLASH-----------) :
[15:46:27 744][HUB5-1][Inf]--Device is connected
[15:46:27 744][HUB5-1][Inf]--Close device handle 0x00000a00
[15:46:27 794][HUB5-1][Inf]--Open device handle \\?\usb#vid_1b8e&pid_c003#5&27e14282&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} 0x00000a00
[15:46:32 860][HUB5-1][Inf]--0-7-0-16
[15:46:32 860][HUB5-1][Inf]--CheckFileRunState succeed
[15:46:32 860][HUB5-1][Inf]-- low_power
[15:46:32 860][HUB5-1][Inf]--Send command success
[15:46:32 860][HUB5-1][Inf]--Read command status success
[15:46:32 860][HUB5-1][Inf]-------------Download meson1.dtb-----------
[15:46:32 860][HUB5-1][Inf]-- download mem dtb normal 79872
[15:46:32 860][HUB5-1][Inf]--Send download command success
[15:46:32 875][HUB5-1][Inf]--Read command status success
[15:46:32 897][HUB5-1][Inf]--Transfer complete
[15:46:32 897][HUB5-1][Inf]--Send download get_status command succeed
[15:46:32 897][HUB5-1][Inf]--get_status success
[15:46:33 409][HUB5-1][Inf]-------------ERASE FLASH-----------
[15:46:33 409][HUB5-1][Inf]--disk_initial 4
[15:46:33 409][HUB5-1][Inf]--Send command success
[15:48:33 410][HUB5-1][Err]--usbReadFile len=512, ret=-116 error_msg=libusb0-dll:err [_usb_reap_async] timeout error
[15:48:33 410][HUB5-1][Err]--Check command return failed
[15:48:33 410][HUB5-1][Inf]--Failure : 1, FailureMax : 3
[15:48:33 911][HUB5-1][Err]--[15:48:33 911][HUB5-1][Inf]--Failure : 2, FailureMax : 3
[15:48:34 412][HUB5-1][Err]--[15:48:34 412][HUB5-1][Inf]--Failure : 3, FailureMax : 3
[15:48:34 420][HUB5-1][Err]--[0x30201006]UBOOT/Disk initialize/Send command/Time out
[15:48:34 420][HUB5-1][Inf]--Close device handle 0x00000a00
I tried using different USB port (both USB2 and USB3) on different computers with different OS (Win7 and Win10), in every cases the box is detected properly by USB Burning Tool but I always get the same error, I can't pass the 7% "formatting..." phase.
I'd be eternally grateful to anyone that can help me get the box working again!
There are currently 1138 users online. 0 members and 1138 guests.
