- I'have the Vega S95_Pro_p200-201604140554 image (not rooted by default)
- I dowloaded the kernel source (arm-src-kernel-2016-05-04-bd1ff1c1cd) from the amlogic site : http://openlinux.amlogic.com:8000/download/ARM/kernel/
- I rebuild the kernel adding the last mali drivers (from amlogic site also) in order to generate the mali.ko module.
- I generate the kernel Image: Image.lzo
- I replaced the uImage file at "kernel" and "recovery " folders withe the image.lzo and the mali.ko in the Vega S95_Pro image
- I repack the image and flash it with the Amlogic USB_burning_Tool.
Result: Black screen
I did this procedure for a kit-kat S805 box sucessfully.
I've tried this with an Android 5.1 Tronsmart image with a S812 MXIII box with the same result but in that case I was able to get the adb connection and logs and I saw that the kernel was loaded but there were some errors related to the user and kernel side mali drivers. I couldn't get the most recents mali drivers to compile for this box though.
I'have no adb connection with this ega S95_Pro image (rooted with EZ Root zip) The box It's just recognized in my windows 7 PC before Android starts.
Have anyone tried this before. Just to modify the kernel and reflash the image?
Am I missing something drivers or boot related?
Do yo get adb connection for this image?
Thank you.
