MXQ QuickPlay custom ROM
    Just to cover my needs (rgb switch for HDMI display issues), I have built a custom rom, taken two as source:
    One from 4pda.ru (http://freaktab.com/forum/tv-player-...smart-firmware) having the rgb mode kernelm, plus other additions such as standby or a lower bar.
    Stock firmware (http://chinagadgetsreviews.com/downl...ay-tv-box.html). This one provides the remote.conf and wifi & bluetooth drivers
    I have set up the init scripts to switch on rgb_mode on boot and enable all CEC configs. rgb_mode will show a greenish screen, reverting by itself to normal after a while.
    SPMC and existing VidOn are installed by default.
    Only things missing are a preinstalled supersu (it was failing on boot, even the su binary has been replaced) and XBMC Launcher (installed butt not booting any player, SPMC nor VidOn)
    And the download link (ready for USB burning tool usage):
    4shared is a perfect place to store your pictures, documents, videos and files, so you can share them with friends, family, and the world. Claim your free 15GB now!
    I suppose a disclaimer isn't needed, but use it at your own risk, and feel free to share your experience.
    I have same problem with Mini M8s, do you know how to apply this fix to my box?
      Unpack the original firmware and the rgb_moded one and just replace files (and rc files). As per http://www.adslzone.net/postt407102.html, the wifi chipset is the same as mxq quickplat, so this firmware should/might be compatible
        Witokondoria,
        how to unpackimg file?I tried with 7zip but it doesn't recognize
          You can depack it with Amlogic customization tool: http://freaktab.com/forum/tv-player-...ion-tool-2-0-7
            I unpacked both imgs, I've seen that tool place upcked files in TMP subfolder, Which file I need to replace?
              it could make a rom, but android 4.4.4?
              mx for our quick play
                Hello Witokondoria
                Any solution to port the force_rgb mode to a S905X Mini M8S II box ???
                Thanks in advance
