Really do not know is it hardware issue or can it be fixed somehow..., please help....., thanks...
MXQ Pro+ DOA
MXQ Pro+ DOA
TV Box is DOA (dead on arrival) - no HDMI signal (no picture showing), USB burning tool cannot recognize Box - only blue light on power plugged in., or male usb, but device manager cannot recognize the device, drivers and Amlogic USB BT - correctly installed (have one M8S bricked and computer recognize it...)...
Really do not know is it hardware issue or can it be fixed somehow..., please help....., thanks...Last edited by sappy; 15 July 2016, 14:32.Tags: None
Hi Sappy. Had a similare issue with the USB burning tool. i eventually found help from some of the guys on here. Use the TWRP method. You can do it via SD card or USB drive. SD never worked for me, but USB did. See post #4 from kamacnik1 with a link to the instructions from Doggyofone.
Worked for me, but now my HDMI isnt working. will need to try and reflash and see. Hope this helps
I manage that computer (USB burning tool) recognize the device - (shorting pins) and I tried to flash "sd-robots fw" (and all other updat fw) - with all preparation according usb burning tool - but nothing worked - USB burning tool always pop-up error - so I think that flash memory chip has malfunction...Last edited by sappy; 27 July 2016, 10:11.
There are currently 2007 users online. 0 members and 2007 guests.
