For starters, let's get a couple of things configured. Make sure you are using the primary USB ports on your PC/Laptop. Make sure you are not using a USB 3.0 port. Make sure that your USB ports do not have power saving enabled. Make sure you are using the S95's OTG port, this is the one closest to the SD card slot.
NOTE: It is very important, that you follow every step as written and in order.
1.) On your computer, go to C:\Program Files\Amlogic\USB_Burning_Tool\WorldCup_Device.
In that folder is an exe file named, "InstallDriver.exe", run that, if you get permission dialog popups, allow them.
2.) Download the correct update file for your device and the version you want, make sure you download the file specified for use with the USB Burning Tool. The file may require extraction to end up with a file ending in ".img".
3.) We are using a method that does not require pressing the Fn switch.
4.) Open the USB Burning Tool and load the update image you downloaded.
5.)Remove the power cable from the S95. Disconnect all USB accessories and disconnect any SATA drive. Remove SD card if one is inserted.
6.) Starting with the Male-to-Male USB cable unplugged from both ends, insert the USB cable in to the S95's OTG port, do not connect the other end to the PC yet.
7.) In the USB tool, leave settings at default, except check "Force Erase All" and click the Start button.
8.) Insert the Male-to-Male USB cable's free end in to your PC.
9.) Watch the tool to see if the S95 gets recognized, if it does the flash should begin.
If after 30-40 seconds it does not recognize the S95, Do nothing to the USB Burning Tool, unplug the USB cable from your PC and wait 5 seconds. Reinsert the USB cable in to your PC. Repeat step # 9. Try this 3-4 times before giving up.
10.) If the flash is successful, plug the power cable in to the S95 and disconnect the USB cable. Stop and close the USB Burning Tool.
