It also has a weak heatsink so if you overclock you will actually slow things down more as the temperature will increase and start to throttle speeds.
Ugoos UT3 RK3288 has a big heatsink and fan so you can increase CPU to 2.0Ghz and RAM to over 650mhz without any side effects.
There is a reason the manufacturer limited it to 1.6Ghz and the RAM to 400mhz.
On my HPH NT-V6 ROM the RAM is set to 533mhz as the better heatsink can take it.
You actually need to increase RAM speed not CPU speed for better video playback and improved performance.
1080p videos shouldn't have any problem, you can try FTMC or RKMC Kodi.
