You're the guru here.,thank you so much for the ROM.
I have a Cloudnetgo CR13 & CR16, both RK3288 with AP6330.
I know it took so much time for building a rom, one or two weeks, so I have to extract the system.img for use with the stock IR remote.And it basically meets my needs,only that it doesn't have the option in "display" for" always hide status bar".
I used your NPH 1.8a's extrated system.img, but audio is not sync with video after some time when streaming.,so have to go back this customized ROM.
So would you have a small change in this cusomitzed ROM as Version 1.1 with the additional option of "always hide status bar" on the bottom?
Thanks again!
