strange case of classic m8s s812 with amlogic s802b inside
hello every one
its been a month looking for a firmware to my bricked m8s s812 (supposed) i found nothing that work for me, i join pic of the box it will say a lot than me
please help at least seems box not dead, connect success with pc and usb burning tool, it a bit weird inside i have s802b amlogic, wifi ap6330 ..........
found once an img for bcm4335 worked without wifi but i need wifi
thanks in advance
Remote with 4 colorful buttons on top
first post so apologize if did something incorrect
You may only view thumbnails in this gallery.
This gallery has 4 photos.
At first i was able to put one firmware cyx_bcm4335.... (I TRIED MANY) on the box but only ethernet no wifi, it was clear i didnt get the right firmware.
Now even that one dont want to work
Errors i have depends: signature verification failed or E: unable to mount...
Or progress bar under android body freezes
When i tried trpw it gives error too like this is a pack for n200 this is a k200 ?
Seller do not answer , cant get the right firmware, pcb look weird bo sign of s812 exept on the site and the box (picture)
Thanks for your help
I had the same box, and it started doing the things your box is doing. I even went and got the Factory flash and still problems. I cured all the problems by tossing it in the garbage and buying something else, like the Sunvell Q-Box.
