[ROM] KII Lollipop
    [ROM] KII Lollipop
    Hello guys,
    Today a give you a little mod to a Lollipop rom made for the KII, both WiFi chips are supported, although i only have the AP6330 version.
    What's on it :
    • Properly rooted with SuperSU. Although this rom brought a SuperUser app, and it was "rooted" it was a security hole. On 4.4 their "root" was to allow every app without the user knowledge or acceptance. Very bad
    • Clean of all junk, obsolete, outdated and apps that you can get in Google Play
    • Added OpenGapps Nano
    • Added init.d support
    • Some more tweaks...
ID:	588637 Click image for larger version
ID:	588638 Click image for larger version
    Instalation :
    • Grab TWRP from here
    • Download the zip and place it on your ExternalSD or USB storage
    • Reboot to TWRP and flash the zip.
    This zip will wipe all of your data
    if [ $up.post.type = $type.two.lazy.to_use_google ] || [ $up.post.type = $type.silly_question ];
    then mv $user.contact.up.post /.trash; set response($response.type = ignore);
    $user.up.post.ignore_in_future = true; fi;
    Nice thank you
      good, i can not wait to have a try thanks
        Not working on M8S
          @abdul_pt, big thanks for this firmware, just ported on my MXIII-G board Netxeon V1.1 n200c , it's all working, wifi, bluetooth, hdmi!!!
            Originally posted by Deanff3
            Not working on M8S
            Should it work ??
            Tapatalked
              Great
              Tapatalked
                Originally posted by abdul_pt View Post
                Great
                Tapatalked
                Can he post for other people to use?
                  Should it work ??
                  Tapatalked
                  I was going to test on my M8S too that has AP6330. Just hadn't got around to it
                    I don't see why not
                    Tapatalked
                      I don't know what isn't working nor the differences between the two devices, but porting it to the M8S should be relativity easy.
                      Tapatalked
                        Should it work ??
                        Tapatalked
                        KII Valkostur worked perfectly in M8S. So I thought it would work this.
                        Gosto de Falar em PT também.
                        Thx
                          Thx
                          Things changed between KK and LL.
                          I also like to speak in PT.
                            First I would like to thank you for your great effort.
                            After installing the new rom I am stuck on the welcome screen going into WiFi screen and again to welcom screen.
                            Look in the photos.
                            I also cannot boot into twrp I tried both the SD card and a USB with the recovery. Img I only see the boot screen
                            After that
                            And again the welcome screen.
                            I tried pressing the reset button and it doesn't work.
                            My device is Kii acemax
                            Please advise
                            Sent from my Nexus 6P using Tapatalk
                              like i said in OP this is a mod of stock KII image from Acemax, so i have no idea what's happen on your device.
                              It works on my KII ap6330 and on others KII ap6335 devices.
                              How are you connecting to the TV ? HDMI 2 VGA cable ?
                              I don't see that desktop image ever
