[ROM] KII Lollipop
I have the M8S version that you cannot boot into recovery and if you brick it you must use the USB Burning tool. I can't install this with TWRP, can you use the USB burning tool? I currently have the BCM4335 chip and 2GB Mem and 16 GB storage. Being that this supports both chips this should work right?? S812 CPU What about OTA?
Originally posted by abdul_ptlike i said in OP this is a mod of stock KII image from Acemax, so i have no idea what's happen on your device.
It works on my KII ap6330 and on others KII ap6335 devices.
How are you connecting to the TV ? HDMI 2 VGA cable ?
I don't see that desktop image ever
I am connecting directly to the TV using HDMI cable.
The only desktop I get is the welcome screen to Android to select language.
Is it possible to connect with adb to device?
Maybe I am doing wrong something. The default way of getting boot into recovery is just putting the recovery. Img on the root of the USB?
Thanks again
Sent from my Nexus 6P using Tapatalk
Originally posted by Pctravel View PostI have the M8S version that you cannot boot into recovery and if you brick it you must use the USB Burning tool.
1) I can't install this with TWRP, can you use the USB burning tool?
2) I currently have the BCM4335 chip and 2GB Mem and 16 GB storage. Being that this supports both chips this should work right??
3) S812 CPU What about OTA?
2) It works for KII, i have no idea about M8S
3) What ??
Thanks again
It's possible to connect ADB remotely. You need to have Ethernet plug in, and them issue 'adb connect YOUR.BOX.IP.ADDRESS'.
On my KII, just putting recovery.img in the root of a FAT formated USB or SDcard and pressing reset button is enough.
You posted a image with a green leaf background.
FAT or FAT32?
Can I force a reflash of the recovery.img using adb?
If so can you please point me to the procedure.?
Originally posted by abdul_ptFAT32
Yes. Open terminal window where you have the recovery.img and issue
Code:adb push recovery.img /dev/recovery adb shell dd if=/dev/recovery of=/dev/block/recovery adb shell sync;sync adb shell rm -f /dev/recovery
Originally posted by cluber77 View PostHi, do we have status bar and navigation bar in this ROM?
thanks
Great rom, Abdul. Thanks!
But some functions are not working (voice search).
There is a firmware from Wetek Core. They blocked boot, but with bootloader from Kii or M8s+ it's working. They solved problem with microphone and there are some more tricks but they are blocked by bootloader.
http://www.wetekforums.com/v/index.php?p=/discussion/28039/wetek-core-os-v2-0-released-by-ota-updatewetekforums.com ist die beste Quelle für alle Informationen die Sie suchen. Von allgemeinen Themen bis hin zu speziellen Sachverhalten, finden Sie auf wetekforums.com alles. Wir hoffen, dass Sie hier das Gesuchte finden!
If you have some time please check it out and may be release firmware based on it (with framerate)
Best regards!
I have tried every possible way of doing this and nothing is working. Let me know if I am doing something wrong ...
I copied your img file and renamed it to recovery.img and put it on TF card into KII Pro. I unplugged the power replugged and it just booted regularly. I then tried to unplugg insert toothpick at the bottom of the box where recovery is and I get into stock recovery. Now last time I tried to hold recovery it just keeps on coming to Octa core logo with Lion. If I completely stop holding the recover button it loads in to Android 5.1 and everything is normal but I would like to load up TWRP. What's the issue?
Which version M8S Ap6330 or BCM ????
Need to update mine as keep getting play store errors and nothing downloads affecting my installed apps #DroidmoteServer
Originally posted by Deanff3 View Post
KII Valkostur worked perfectly in M8S. So I thought it would work this.
Gosto de Falar em PT também.
Thx
Thanks for posting this info regarding the M8S.
Bricked:
DEVICE M8S 2G/8G (SkyKirin/n200)
WIFI AP6330
MBX/n200/n200:4.4.2/KOT49H/20160706:user/test-keys
Originally posted by Deanff3 View PostNot working on M8SOriginally posted by Deanff3 View Post
ThxLast edited by FerociousAndroid; 23 January 2017, 04:36.
There are currently 1804 users online. 0 members and 1804 guests.
