M95 Amlogic S905X Quad Core TV Box 1/8GB 10/100 Lan 2.4Ghz WiFi +BT
    ● Amlogic S905X CPU
    ● 1/8GB Ram
    ● 2.4G WiFi + 100M LAN + BT
    ● 4K x 2K H.265 decoding demonstrates the high-premium visual effects.
    Gearbest
    Hi, does anyone have firmware for this box or know of what's compatible? It is the same as this M95 box at Gearbest:
    Have not been able to find a firmware for it...
      Does anyone know if this is compatible with any of the Amlogic references like P212?
        Has realtek 8189 wifi chipset and Sandisk flash.
        Have tried a variety of S905X / 1Gb / 8189 IMGs, they will not flash.
        Have tried some M8S+ S905X IMGs, they will flash but will not boot, and brick the box ( you get startup logo but wont boot, and also will not boot into recovery with button hold, and the only way to fix is to short pins on the NAND to be able to flash it again).
        ^Example. This will flash but box will brick and not boot past startup logo and refuses to go into recovery. No other imgs/or zips I tried for S905X MXQ Pro variants works. P212 roms also do not work.
        Patching the above rom with the S905X TWRP recovery does not work, you cant boot to recovery, even if I patch bootloader from a different rom. I had to patch the above with a different UBOOT to be able to get into recovery, and even then TWRP will refuse to mount any partitions.
        So it seems the only way to unbrick this thing is to have an original firmware, if anyone knows where I can find one for the M95..
          Hello, no news about this? I have this M95 tvbox and I need the ROM.
          Thanks in advance.
            Thanks in advance.
            Yes it is basically a P212 variant, if you open it up you'll see it on the board, but only mxq pro s905x roms will work. I believe this one worked for me.
            Can you do me a favor? Are you able to copy the remote.conf file from the /system/etc directory and send to me? Or cut and paste the text here?
            If so I can make an Android TV firmware for this box, last thing I need is the remote file . Thanks
