mxq s805 v3.2 20160229
    My mate reset his box now it wont boot, blue light comes on solid, nothing on screen, tried toothpick for recovery but nothing happens.
    Anyone any ideas how to recover this unit.
    The white sticker on reverse side reads:
    1g 8g ssv605 ip
    160531032-16
    gms 160603
    Thank you.
    Anyone help me get this up and running again?
    Thank you
      Amlogic USB burning rom if you have firmware for it.
      i'm looking for firmware forthis model if you have it
        http://mega-tron.tv/ or http://chinagadgetsreviews.com/downl...-tv-box-2.html
          Thanks .the firmware worked but wifi not working. Do you know how i can find out which wifi chipset i have
            EM6Q (MXQ Version ) firmware list HD18Q http://www.enybox.com/En/news/html/?447.html
            have a look here and have a go with the stock firmware this should get your wifi going
              Thanks but this firmware didnt work. It wont even load into recovery. Do you know how i can find out what my wifi chipset/module is?
                You have to open the device to find out the wifi chip.
                I don't think you will get working firmware for such an old tv box.
                  China Gadget Reviews has this. I do not own this box and cannot know if this firmware is for your box or any benefit. I think it is a different link than the China Gadget Reviews link above.
                  As always, the risk is that of the user.
                  Good luck..
                    Mine is dated 29-2-2016, I believe it’s newer than the original MXQ that got released. I have opened up the device but I don't know where the chip is located to read it.
                    I purchased this from **** and seller sent me firmware. The firmware package they sent looks different from all the other files I’ve tried. I loaded this on to the SD card with holding reset and still not luck. The box doesn't even respond to the firmware. I've attached a picture of the package.
                    Good luck..
                    I've tried most of the MXQ firmware from that site but haven't had any luck. I’m hoping someone can point into the right direction as where the wifi chip is located on my board. Then once I identify it I’m hoping to get driver and inject into the firmware. I've atatched a picture of the board. Click image for larger version
                      I cannot tell from the picture, it needs to be better. The WiFi module will usually be very close to where the antenna lead is soldered to the PCB(board). If you list the numbers on the chips in that area, somebody will recognize the WiFi chip name.
                      Cheers.
                      BTW, Look through here and see if anything looks promising....scroll down.
                        Cheers.
                        we have a winner.
                        thanks for all you help guys/.
                        I finally got it working using the beow firmware
                        http://blog.geekbuying.com/index.php...ware-20160825/
                        thanks again guys. it took me weeks to find a firmware to fix the wifi issue.
                          that dos work in my box, i was months without wifi and remote, but now is fixed, but it dosent work the xbox 360
