just picked up an MXQ Pro 4K android box from bangood
http://www.banggood.com/MXQ-Pro-4K-U...p-1015008.html
and i've been trying to get the thing into recovery mode but no luck so far. T
The reset switch is located at the back of the spdif port and powering the device up with it depressed does absolutely nothing it just boots up as normal.
While the reset button itself works from a functional standpoint (tested continuity across the pins), one of the pins on the underside of board appears to not be connected to anything?
