OTT MXQ Pro 4k Recovery mode/reset button
bought this box today and went to flash 7.1 in the usual usb flash tool (2 male usb) method, toothpick goes all the way... in so i whipped the top off and low and behold there IS NO RESET SWITCH INSTALLED. the cheap b'tards have removed it to save cost, the PCB has 2 empty holes right where the microswitch should be surface mounted behind the AV port - switch is simply not there. Will try installing boot to recovery app and installing from sd
There are currently 2890 users online. 5 members and 2885 guests.
