Firmware For The MX9 RK3229 TV Box...
    I do not own this device.
    I saw the post and thought someone might need it.
    As always, installing firmware is the user's risk and responsibility.
    It is the user's responsibility to select and install the correct firmware for their device.
    From China Gadgets Reviews. See Here.
    My apologies if this is old news.
    Thanks, I'll be trying that in the next few days as I am having an issue with Kodi on my MX9.
    Happy New Year.
    The Case for Reform
    Drug Science Prof D. Nutt
    The life of a good person means more to me than that of a bad person.
    I have no borders as far as good people go.
      Ok, Happy New Year!!
      Kids are back at school and now I'll have time to try the firmware update.
      What is the easiest way to do the flashing that doesn't involve the need to have three hands.
      The Case for Reform
        Have a look here. It is for a different RK3229 box, but the procedure should work for you.
        Disregard the part that defines the USB OTG port, I do not know which port on the MX9 is its OTG port. Hopefully it is labeled. Also don't use firmwares posted there.
        Good luck.
          Thanks RISCy, I'll let you know how I get on.
          The Case for Reform
            Ok, as you can see I was successful in installing that firmware. https://1drv.ms/v/s!Ak83Vw_Z13GFhcsEF4fO41t4sblLHg
            Unfortunately though it did not solve my issue with Kodi which once installed did the same sub menu disappearing act as described here.. http://www.noobsandnerds.com/support....php?tid=17314
            Seems I will need to find a firmware that does not run the Box Installation Set Up when rebooting.
            Um.
            Just to let people know, the USB socket to use is the one at the back and the reset button is in the AV socket.
            The Case for Reform
              Ok, I downloaded the basic FW with 4.4.04 Kitkat from that same link on China Gadget Reviews.
              So far so good as far as kodi goes.Jarvis 16.1 running now. Test will be if it is still running tomorrow.
              Will keep you updated.
              Thanks for the help.
              The Case for Reform
                Hello KBL, Glad to do it.
                Good to know you are making some progress. You might want to check back to that site every now and then for anything new.
                Good luck with the testing.
                Cheers.
                  Well, I think I can safely say that this issue is now resolved.
                  In fact, the box is running very sweetly.
                  I am delighted.
                  Many thanks!
                  Just hope the vendor doesn't find out since they issued a refund.
                  The Case for Reform
                    It says that it can 4k resolution but I get HD 720p maximum. Did anyone check?
                      Not checked, but I would think that the 4K streams etc are few and far between. I can get plenty of 1080Hd streams.
                      You could test by putting a 4K vid on a usb stick and playing it via the box.
                      Personally, I'm not a big fan of 4K. I like my images more realistic,
                      The Case for Reform
