Firmware Upgrade Guide for Rockchip devices
Originally posted by deetucks View Posthttps://chinagadgetsreviews.com/down...ni-tv-box.html
i tried this but it reach 98% and give an error ..[0x30401002]UBOOT/partition/bootloader./identity/USB control setup
what about the Rom of Nayam Amarshe for S905W SoC ??? shall it work , you can ask there ,
to find under "TodaysPosts"
good luck / gefattern
Hi guys from Italy.
I've a MXQ Pro 4K (pic 1) bricked, blocked on MXQ logo.
It seems a Rockchip device (as you can seen in the pic).
I tried to unbrick with the SD method: failed (pic 3).
Anyone can help me? What is wrong?
Thx in advance
SecYou may only view thumbnails in this gallery. This gallery has 3 photos.3 Photos
Thx in advance
Sec
use the PC Way , works much better , if you need more Info ask ,
greetings / gefattern
Thx pal!
Which way is better, Rockchip batch or Android tool?
Listen it's not so easy identify the box w/this methods
for a Newbie the Batchtool is the little bit easier Way , because this Tool has only
one Tab , but the Way is on both the same , loading .img to Tool , prepare Box for
flashing and go , AT has additionally , part flashing , and some Test things , so for
you , BT is good , you can try AT too if you want , with AT you can make a full copy
of the installed Rom , ask if you need more help , greetings / gefattern
There are currently 1709 users online. 1 members and 1708 guests.
