Acemax M12N Modded ROM
    Originally posted by trebor View Post
    Have reflashed to ensure it was Clean and erased all,
    System UI crash and soon as any app decides to run sideways (fails rotate to normal) Weird
    Went back to previous rom (non modded) apps that run sideway no UI fail, so maybe a tweak or a twerk missed the rom
    That's really odd.
    I'm guessing that the hardware in your Yoko is exactly the same as in the M12N?
      Pictures are up completely different....
        Ran some general tests in Kodi and SPMC and the same general minor issue is present but a little more pronounced than in other players.
        SPMC has a having of crashing when exited but that is a very minor issue.
        Had Kodi crash on me twice. On both occasions I was navigating NAS folders.
        Now that Kodi 17 has entered Beta stage I'm going to test it and see how it compares.
          Ran some tests on Kodi 17 Beta 1.
          The good news is that video playback is a little smoother but still not quite as it should be.
          The bad news is that there is no passthrough AC3.
          Still a work in progress of course with 17.
          I did spot a new feature (or at least one that I have not seen or noticed before and that all of your Android apps are shown in an apps category, so you can launch them straight from Kodi if desired.
          Could be useful in future for those that might want Kodi as a main launcher.
            Good catch, bluesmanuk !
              Can I use this ROM in my beelink gt1?
              Inviato dal mio MI 5 utilizzando Tapatalk
                It's possible but you may find that some features may not work.
                The GT1 has Gigabit ethernet and at the moment the AceMax has 100Mb, so this may not work.
                Other devices such as Bluetooth and Wireless will depend on what hardware Beelink have chosen to implement.
                It would be a case of try it and see.
                  If anyone messing around with screen rotation then insert in build.prop the following.
                  persist.demo.hdmirotation=portrait
                  That rotate the screen portrait this works on Android 5.1 and 6 on Rockchip devices.
                  From Neomode.
                    From Neomode.
                    So I am guessing that this setting will allow an app that is designed to run in portrait mode to do so on demand so to speak?
                      Yes
                        I tried and install failed signature.
                          Hi do you think the dts fix apk might work on gt1? Can you share the apk? Pleaseer.
                            Can we use the gt1 launcher or any other suggestions aside from nova? The stock launcher is a bit boring...
                              I'd like the apk for the dts fix to try at the gt1.tnx
                              Στάλθηκε από το Broken powered G2 D802 μου
                                Should be able to find it here
