I manage to burn it to the nexbox A1 using USB Burning tool and the image got loaded fine; however been your wifi drivers different than nexbox's one I got stuck at the initial setup as it requires a wifi connection.
Ok so i opened your ROM withthe amlogic customization tool and replaced your wifi, bluetooth folders and the remote file (all the /etc folder) with the ones included in the nexbox, repacked and tried to flash the image using USB burning tool - it should work right? Instead it didn't, it allways gets stuck at 98% with the error: UBOOT/Partition boot/Initialize partition/Error result.
I tried to change the options in the USB Burning tool to erase flash and bootloader but it didn't make any difference.
I read the instructions here: http://www.cnx-software.com/2016/08/...x-s905-tv-box/
and I thought it would be a simple job...
I am new to the game so I am sure I am missing something basic here :-(
