Inphic i7 Amlogic S905X Android 6.0 2G/16G 4K UHD Smart TV Box 802.11 b/g/n LAN HDMI CEC
Additional tests showed that without changing the case, software problem is not completely solved. Redid the enclosure and added the fan (while it is connected to USB). According to the test results - temperature under maximum not exceed 65-68 degrees. In normal usage be in the range of 38-57 degrees. When you connect the fan to USB port of TV box, it will automatically turn on at startup and off when you turn off the system (disconnect the connector is not required).
You may only view thumbnails in this gallery. This gallery has 3 photos.3 Photos
New Firmware (finally)
Glad to share the PC upgrade firmware for Inphic i7
1G/8G PC Upgrade Firmware
2G/16G PC Upgrade Firmware
Flash guide, please refer to: http://blog.geekbuying.com/index.php...utorials-tool/
Have fun !
Best regards
blog.geekbuying
Have fun !
Best regards
blog.geekbuying
any update firmware for i7 pro? can i upgrade it via SD card?
the main website inphic.com is down
There are currently 903 users online. 0 members and 903 guests.
