i think this box is eof...
Linux for Amlogic S805
Hope someone can point me in the right direction,
I downloaded the Armbian_5.44_S805_Ubuntu_bionic_3.10.108_server_20 180521.img image and booted successfully from an sd card and executed /root/install.sh as the root user, but when I remove the sd card and reboot, the s805 boots into busybox.
Have anyone successfully installed it onto their system without the need to have the sd card in the whole time?
thanks
Originally posted by IMartins View Post
can you share link and instruction to downlaod and boot from sd card?
thanks
all the info is on http://mxqproject.com/
I have a Amlogic s805 box, info and links can be found here:
http://mxqproject.com/tutorial-s805-...-mxq-s805-box/
this is for mxq, i have minix x6.
do you have boot armbian on minix x6?
is there a google app like zcup that tells you the system board? really dont want to have to dismantle it again...
the linux site Yandex.disk has sooo many distro's versions - how to know which is the correct on?
hoping to get linux on a MXQ S805; never got wifi working on it - hoping linux fixes that and i can setup as a Plex server
thank you!
What prevents you from trying to run Armbian ?Originally posted by astrid View Post
Originally posted by balbes150 View PostWhat prevents you from trying to run Armbian ?
This is the dtb.img if you want to include to the others:
The distro works well with this device but the Wi-Fi fails in the first time, it could be because the device does not have Ethernet port.
Regads.
>$trid
There are currently 2051 users online. 3 members and 2048 guests.
