Have searched everywhere for a rooted rom with google play store for the Polaroid PTAB8000 8inch tablet but no luck. Assume either not availble or just not a popular tablet? Or other roms here for Polaroid tabs might be compatible?
PTAB8000 Rooted Rom with Google Play Store?
I have a PTAB8000 Rooted and with Playstore.... Took no time to do either.
Basically the steps I took was I went to the vendor support website for the tablet and downloaded "PTAB8000_Firmware_SD_OTAv2.zip" (about 140mb).... Flash your tablet with this.
Then do a google for "PolaroidAIOv2.1b" its a custom program a developer made to root the device. I will say however that after running the program, everything worked and all steps were performed in the program; however at the end it said the device was not rooted which was false. It installs SuperSU on it, and well it definitely has root access.
Then find yourself a PlayStore .apk and throw it in. I cant remember if there was an accountsync/services apk as well which was installed? I picked this tablet up a few weeks ago and have had no issues since. Seems to be well rounded for the most part.
Hope this helps.
There are currently 2922 users online. 0 members and 2922 guests.
