Nexbox A95X 2/16gb modded rom combined with MINI M8SII firmware
    looks like you are using older burning tool as well
      Thank you for the rom but I want to ask something .
      I got one a95x, one a3 and one bb2.
      (The a3 I will expect it in Monday)
      in the 2 other I noticed there is no navigation bar, no notification bar and no recent apps.
      what is that a new way from the Chinese manufacturers?
      Did we have in the future an Ota or we forgot it?
        as said... i'm not a rom developer
        if i will do a new version will be because i need it, otherwise for me it's fine like this
        i saw that the firmware propose to update firmware as M8SII.... i don't know what will happen doing that upgrade
        if it changes also level 1 part of the rom we would lose remote control to turn device on.
          Use Pharjister rom all you need in that one.
            I flashed the rom with the steps of lothian77
            And without checking Erase bootloader I have this error
            Checking Erase bootloader I finally flashed
            all seems works fine except remote control
            Remote doesn't functions at all
            P.S.
            I have seen that in the options/more settings/display there is no way to set the system background
              you must go in settings and activate remote control (it is off by default)
              it it still doesn't work, put correct remote.conf in /etc
                I have switched on
                I have the default factory remote
                I have found the right config file
                remote.conf.txt
                  I have tried with two remote.conf files but same malfunction
                  Home Button, Kodi button, Live tv Button not works at all
                  I have copied the config file from the original rom too, but same result
                  original remote.conf.txt
                  Some help ? Someone can give me the right config file (Nexbox A95X S905X 2/16) or tell me how to config ?
                    This rom works only with the Nesbox? Could I try to flash it on the Mini M8SII too?
                      they don't work also for me.
                      i never realized.
                      i use the remote just to turn on device, after i use mouse and keyboard
                        i never realized.
                        I hope someone can help us
                          did you find a solution for the special remote keys?
                            I'm customizing my official rom by myself (only root now) and the special keys are all ok
                            I suppose that every box has a own remote config
                            Now I would like to improve with the status bar and notification.................
                              Hi, you mean this one ?
                              Can it be flashed with sd card method ?
                              Sent from my ONE A2005 using Tapatalk
                                Loving it, thanks
                                Neil
