Nexbox A95X 2/16gb combined with Frankenstein firmware for stock remote functionality
Originally posted by kzkz View Post
But the original nexbox a95x 2g/8g firmware make suspend instead of power off
I believe suspend doesn't work in TX5 pro rom.Last edited by Krisshin; 17 October 2016, 05:52.
Originally posted by KrisshinWould be awesome if you can figure this out. I will be glad to repack the rom with your findings.
Or better replace the config file as I have the same device as yours.
Originally posted by Krisshin View PostHi all,
Combined Nexbox A95X 2/16gb 160806 with prahjister's frankenstein firmware.
This firmware is basically a frankenstein firmware with A95X stock remote functionality. (power on/off and etc..)
I needed to use stock remote and lothian77's firmware based on Mini M8s II worked ok by replacing remote config with A95X one,
but Mini M8S II stock firmware just didn't cut it for me.
I have already included A95X remote config as a default, so you don't need to change it.
Big thanks to prahjister for his dedicated work and inspiration!
Enjoy!
so i have a95x and my picture goes pale. the suplier gave me the instructions how to flash it so i got working on it. i got to the point where i installed the usb burning tool and the image. however the burning tool doesent recognise the device.nothing happens.i have a reset button i do the holding the reset button and plug the ac cable but nothing works. note i do this on pc. pls heeeeeelp
Originally posted by mazence View Postso i have a95x and my picture goes pale. the suplier gave me the instructions how to flash it so i got working on it. i got to the point where i installed the usb burning tool and the image. however the burning tool doesent recognise the device.nothing happens.i have a reset button i do the holding the reset button and plug the ac cable but nothing works. note i do this on pc. pls heeeeeelp
There are currently 1877 users online. 0 members and 1877 guests.
