KM8 Pro Android 6.0 TV Box with Octa Core
    - S912 Cortex-A53 octa core CPU
    - Newest Android 6.0 system
    - Bluetooth 4.0 connectivity:
    - 10 / 100 / 1000Mbps Ethernet:
    - Dual WiFI
    - 2/16GB
    Gearbest
    5 bucks off with KM8Pro
    WWP1610072129554789 ok when deliver. I place order over 3 seconds ago why no update???
      Did you order more than one, that usually helps
        Ahhhhh thats the trick
          Received today.
            is it worth this box, is it working normal?
            does it received an Ota ?
            Does it have navigation/status bar?
              There is no OTA update ... only information about new software ... and no further action.
              Manual local update possible from SD card to a new KM8PRO-ota-20161010.201106.V070 firmware.
              After update - status bar on/off , removable storage type confirmed, ...
              There is no Navigation Bar auto-hide functionality.
              You Tube special (red) version comes with software (not possible to change to official one from google play) but You can live with that one.
              Still waiting to have a custom rom ;o)
              Please let me know if there is , or will be any change in functionality.
                looks normal, at list it have the information about new software.
                About the navigation bar I did not understand.
                When I am on full screen with Kodi or YouTube what happened with Nav bar?
                Ann what about the status bar, can I Swype down to aappear?
                I think this box is from videostrong, but i can not find where is the "videostrong Downloads".
                Not only for this box, I have the kii pro and i can not find anything "official"
                  It is the Same Box as the YokaTV, and the Mecool 32/16 Version. It eben has the Same boot-up lile the YokaTV, but obviously with a slightly different branding (KM8 vs. YokaTV).
                    drdedus
                    In Kodi Nav bar hides from the very beginning,
                    In You Tube not possible to hide Nav bar - full screen is not the solution for that.
                    Yes You can swipe down Status bar.
                    There is no support from The Manufacturer (at least on his official web page)
                      In YouTube it is not a solution to get into full screen, but when when you get into, the navigation bar is disappearing?
                      About the support and the update how all this works?
                      You said you have a notification about New firmware.
                      But where do you know where to download, is providing a link through the notification or you have to look in forums to find something?
                      Generally I do not understand where and how they find all the people in forums the new firmware m
                        No ... nav bar is still on.
                        Firmware ... uncle google "km 8 pro firmware" ;o)
                          All this boxes is rooted.
                          Can we easily disable the bar and install an alternative from store or from another box?
                          many boxes have similar problems.
                          is there any solution for this?
                            does the km8 pro suffer from high temperature and "dark colors" like nexbox a3 etc?
                              Please someome can answer if the box have the issue with the very dark colors like nexbox a95x and A3?
                              I am one step to order so please give me your info about
