Weather in home screen
    I try to set the weather in home screen like in the images of qbox advertisement but i cant!
    So how can i set weather in hone screen?Do i need an app?
    Sent from my iPad using Tapatalk Pro
    Wondering the same thing. When my box boots it comes up briefly with New York and Query but it doesn't matter what I type in the 1st box and then click on query they both eventually just disappear
      Exactly the same behaviour!!!
      Sent from my iPhone using Tapatalk Pro
        Try this. I did 2 things but not sure which one actually worked. Go into settings then location. I chose Battery saving mode (WIFI and cellular). Then open the default browser and allow it to determine your location.
        Reboot and see if it works. Mines is working now but like I said I also did something else at the same time as changing these settings before I rebooted.
          Ok i ll try,but you dont reminder What else you make!!
            Yeah, I decompiled the apk and re-wrote some of the code. That said mine isn't working tonight again
              I try what you write,but still no luck!!!
                I think I've fixed it. Had to rewrite some code in the classes.dex file but has been working since last night, using various locations.
                Backup the original "SunvellWin8Launcher.apk"
                Copy the downloaded "SunvellWin8Launcher.apk" to "system/app/SunvellWin8Launcher" folder and change the permission to 644 then reboot system.
                Not sure if it makes any difference but I am using the correct Country code as well now.
                Ignore the bottom link, added in error and now can't remove it
                  Thanks i ll try tomorrow
                    As am i New on Android,could you tell me with which application and how can i change permissions?And also i change permissions to the folder not only to apk,am i right?
                      You need root explorer or a similar app to add and remove files from the system folder.
                      1. Download "SunvellWin8Launcher.apk"
                      2. Go to "system/app/SunvellWin8Launcher" and backup the original SunvellWin8Launcher.apk (copy it to somewhere safe).
                      3. Copy the file you downloaded "SunvellWin8Launcher.apk" to "system/app/SunvellWin8Launcher".
                      4. Change the permissions of "SunvellWin8Launcher.apk" to 644.
                      You are leaving the original "SunvellWin8Launcher" folder where it is so you don't need to change the permissions for it.
                      It is definitely fixed as mine is still working nearly 24 hours now.
                        Thanks man,i ll try...!!!
                          Its working fine in super celerons rom and dts works in that as well 😁
                            Weather didn't work for me in super celeron either.
                              Thanks!!!Word great!!!
                              Can i ask you the file that i took back up,do i need it to something??
