Weather in home screen
    If the weather is working then no real need to keep it but always best to keep it just in case.
      Ok,it Is 2mb the original so i ll keep it,just in case
      Sent from my iPad using Tapatalk Pro
        Where to. Change the permissions of "SunvellWin8Launcher.apk" to 644. change and how?
        I know you need root explorer or a similar app to add and remove files from the system folder.
        Bud where doe you change the permission to 644?
        Thanks in advance
