Mini M8S S905 Ubuntu Mate 64 bit (With X and Kodi and VLC) on SDCard
Originally posted by Fabbione View PostIs this compatible with the mini m8s II featuring the amlogic s905x soc?Android TV Box - Mini M8S (Amlogic S905) - Ubuntu Mate 16.04 Arm64 - 3.14.29 with VLC (X11 Accelerated XCB), Kodi Odrobian Fbdev 16.1 (VPU Accelerated), X.org 7.7 plus Mali Fbdev 20160315-r5p1
Libreelec on my mini m8s works perfect but when i try this ubuntu or debian/armbian images I always have black strips on the image no mater if its in console or X. Tried on 4k tv and hdmi to vga adapter, is always the sameYou may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by dkuku View PostLibreelec on my mini m8s works perfect but when i try this ubuntu or debian/armbian images I always have black strips on the image no mater if its in console or X. Tried on 4k tv and hdmi to vga adapter, is always the same
Have you tried to change the Color Depth to 24mbp using this http://www.mediafire.com/file/iuobso...-24mbpp.tar.gz
What you have, Mini M8S with S905 or with S905X (Mini M8S II) ?
Originally posted by dkuku View PostI spend the whole day yesterday with different setups and different images and I managed to run this rom by lowering the display resolution to 720p60hz and changing the next option in the file (hpd, or similiar-I have to check) from true to false in the s905_autoscript file.Android TV Box - Mini M8S (Amlogic S905) - Ubuntu Mate 16.04 Arm64 - 3.14.29 with VLC (X11 Accelerated XCB), Kodi Odrobian Fbdev 16.1 (VPU Accelerated), X.org 7.7 plus Mali Fbdev 20160315-r5p1
Originally posted by dkuku View PostIf you can update in the first post also that after flashing its good practice to regenerate the ssh server keys -this should be secret and by flashing rom image everyone has the same which is a security issue and delete the anime and music folders.
so i never change the ssh key... >.<Android TV Box - Mini M8S (Amlogic S905) - Ubuntu Mate 16.04 Arm64 - 3.14.29 with VLC (X11 Accelerated XCB), Kodi Odrobian Fbdev 16.1 (VPU Accelerated), X.org 7.7 plus Mali Fbdev 20160315-r5p1
Awesome job! Where did you get the RTL driver from? Was it included in the hardkernel linux source tree?
(I'm building something similar, but with Arch's C2 kernel and root instead of Ubuntu. I did get X working, but not wifi, and can't find a way to get the RTL8723bs to compile out-of-tree)
Originally posted by jimreynold2nd View PostAwesome job! Where did you get the RTL driver from? Was it included in the hardkernel linux source tree?
Then i found out its RTL8732BS, so i get the Driver from LibreELEC Kernel Source in here https://github.com/kszaq/linux/tree/amlogic-3.14.y
Then i use the same Kernel Header version from my current Kernel version And Kernel Source 3.14.79.
- My current kernel - http://deb.odroid.in/c2/pool/main/l/...0926_arm64.deb
- Kernel Header - http://deb.odroid.in/c2/pool/main/l/...0926_arm64.deb
- Kernel Source - https://github.com/hardkernel/linux/...rnel-84.tar.gz
i found error WARNING: "extern_wifi_set_enable" [/usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/8723bs.ko] undefined!
after i ask Google, i do this trick http://forum.armbian.com/index.php/t...ailable/page-2 and check https://github.com/jwrdegoede/rtl818...platform_ops.c
You need to remove line 33 to 38
Here my Compile log:
Code:root@odroid64:/usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS# make make ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- -C /usr/src/linux-headers-3.14.79-84/ M=/usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS modules make[1]: Entering directory '/usr/src/linux-headers-3.14.79-84' CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/core/rtw_cmd.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/core/rtw_security.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/core/rtw_debug.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/core/rtw_io.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/core/rtw_ioctl_query.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/core/rtw_ioctl_set.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/core/rtw_ieee80211.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/core/rtw_mlme.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/core/rtw_mlme_ext.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/core/rtw_wlan_util.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/core/rtw_vht.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/core/rtw_pwrctrl.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/core/rtw_rf.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/core/rtw_recv.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/core/rtw_sta_mgt.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/core/rtw_ap.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/core/rtw_xmit.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/core/rtw_p2p.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/core/rtw_tdls.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/core/rtw_br_ext.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/core/rtw_iol.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/core/rtw_sreset.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/core/rtw_btcoex.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/core/rtw_beamforming.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/core/rtw_odm.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/core/efuse/rtw_efuse.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/os_dep/osdep_service.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/os_dep/linux/os_intfs.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/os_dep/linux/sdio_intf.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/os_dep/linux/sdio_ops_linux.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/os_dep/linux/ioctl_linux.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/os_dep/linux/xmit_linux.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/os_dep/linux/mlme_linux.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/os_dep/linux/recv_linux.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/os_dep/linux/ioctl_cfg80211.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/os_dep/linux/rtw_cfgvendor.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/os_dep/linux/wifi_regd.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/os_dep/linux/rtw_android.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/os_dep/linux/rtw_proc.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/os_dep/linux/custom_gpio_linux.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/hal_intf.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/hal_com.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/hal_com_phycfg.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/hal_phy.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/hal_dm.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/hal_btcoex.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/hal_hci/hal_sdio.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/led/hal_sdio_led.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/HalPwrSeqCmd.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/rtl8723b/Hal8723BPwrSeq.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/rtl8723b/rtl8723b_sreset.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/rtl8723b/rtl8723b_hal_init.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/rtl8723b/rtl8723b_phycfg.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/rtl8723b/rtl8723b_rf6052.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/rtl8723b/rtl8723b_dm.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/rtl8723b/rtl8723b_rxdesc.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/rtl8723b/rtl8723b_cmd.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/rtl8723b/sdio/sdio_halinit.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/rtl8723b/sdio/rtl8723bs_led.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/rtl8723b/sdio/rtl8723bs_xmit.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/rtl8723b/sdio/rtl8723bs_recv.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/rtl8723b/sdio/sdio_ops.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/rtl8723b/rtl8723b_mp.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC/phydm_debug.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC/phydm_AntDiv.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC/phydm_AntDect.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC/phydm_interface.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC/phydm_HWConfig.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC/phydm.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC/HalPhyRf.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC/phydm_EdcaTurboCheck.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC/phydm_DIG.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC/phydm_PathDiv.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC/phydm_RaInfo.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC/phydm_DynamicBBPowerSaving.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC/phydm_PowerTracking.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC/phydm_DynamicTxPower.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC/PhyDM_Adaptivity.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC/phydm_CfoTracking.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC/phydm_NoiseMonitor.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC/phydm_ACS.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC-BTCoexist/HalBtc8192e1Ant.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC-BTCoexist/HalBtc8192e2Ant.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC-BTCoexist/HalBtc8723b1Ant.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC-BTCoexist/HalBtc8723b2Ant.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC-BTCoexist/HalBtc8812a1Ant.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC-BTCoexist/HalBtc8812a2Ant.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC-BTCoexist/HalBtc8821a1Ant.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC-BTCoexist/HalBtc8821a2Ant.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC-BTCoexist/HalBtc8821aCsr2Ant.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC/rtl8723b/HalHWImg8723B_BB.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC/rtl8723b/HalHWImg8723B_MAC.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC/rtl8723b/HalHWImg8723B_RF.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC/rtl8723b/HalHWImg8723B_FW.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC/rtl8723b/HalHWImg8723B_MP.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC/rtl8723b/phydm_RegConfig8723B.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC/rtl8723b/HalPhyRf_8723B.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/hal/OUTSRC/rtl8723b/phydm_RTL8723B.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/platform/platform_ops.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/core/rtw_mp.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/core/rtw_mp_ioctl.o CC [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/core/rtw_bt_mp.o LD [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/8723bs.o Building modules, stage 2. MODPOST 1 modules CC /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/8723bs.mod.o LD [M] /usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS/8723bs.ko make[1]: Leaving directory '/usr/src/linux-headers-3.14.79-84' root@odroid64:/usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS# insmod 8723bs.ko root@odroid64:/usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS# dmesg | tail [29360.287912] hdmitx: system: irq 80000002 [30151.783890] No module found in object [30938.147155] 8723bs: version magic '3.14.79 SMP preempt mod_unload aarch64' should be '3.14.79-84 SMP preempt mod_unload aarch64' [30972.107203] 8723bs: version magic '3.14.79 SMP preempt mod_unload aarch64' should be '3.14.79-84 SMP preempt mod_unload aarch64' [31432.906651] 8723bs: version magic '3.14.79 SMP preempt mod_unload aarch64' should be '3.14.79-84 SMP preempt mod_unload aarch64' [32653.167870] 8723bs: Unknown symbol extern_wifi_set_enable (err 0) [33620.833627] RTL871X: module init start [33620.833643] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844 [33620.833647] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844 [33620.833760] RTL871X: module init ret=0 root@odroid64:/usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS# root@odroid64:/usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS# make install install -p -m 644 8723bs.ko install: missing destination file operand after '8723bs.ko' Try 'install --help' for more information. Makefile:865: recipe for target 'install' failed make: *** [install] Error 1 root@odroid64:/usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS# make install mkdir /lib/modules/3.14.79-84/kernel/drivers/amlogic/wifi install -p -m 644 8723bs.ko /lib/modules/3.14.79-84/kernel/drivers/amlogic/wifi/ /sbin/depmod -a root@odroid64:/usr/src/linux-headers-3.14.79-84/drivers/amlogic/wifi/rtl8723BS#
And I dont know how to edit the autoscript file
There are currently 4754 users online. 1 members and 4753 guests.
