V88 PRO - NEOMODE CUSTOM ROM
Originally posted by jamigf View PostScooter thank you for answer, sorry but I not understand, ezroot work with v88 pro original firmware?? if yes what is the procedure for root?
Originally posted by Aquox View PostUhm ok thank youbut there is another rom for scishion v88 pro? i can't use it with the stock rom, it is too slow
Kevin's uses the stock launcher, while Scooter's gives you a choice between TV Launcher and Sun.
http://androidpcreview.com/how-to-use-the-amlogic-usb-burning-tool-to-manually-update-firmware/3749/These days, more Android TV boxes are making it easier to update firmware by using FOTA - Firmware Over The [...]
First things first is you need an A to A usb cable. ie male to male http://www.****.com/itm/3ft-USB-2-0-...0AAOSwT5tWGO1x
Originally posted by Aquox View PostOk thank you, i followed the guide but i have a little problem, i'm not able to go in recovery mode with this scishion v88 pro, there isn't a button recovery mode and there isn't a power button. Can you explain me how to go in recovery mode?
There are currently 2267 users online. 0 members and 2267 guests.
