Maximum wifi speed for CX players
The Speed you getting on Wifi is depending on the follow things.
- The Internal Antenna
- The Wifi Router Setup
This means when you are on a Chanel with many other Stations your Wifi Speed will
drop.
You can try the follow Change your Wifi Chanel or Modding your Internal Antenna.
Most of it, it is enough to put the Antenna Outside of the Housing.
Neomode
Am aware of the following. Thanks. I'm asking about the hardwares of the android box.
Originally posted by neomode View PostThe Speed you getting on Wifi is depending on the follow things.
drop.
Neomode
forget about the connection speed, i'm more interesting in real-world benchmarking. I always connect at 65mbit, with -40dbm signal strength and zero interference (no other 2.4ghz networks in range). my router is directly above my tv, one floor up.
if i point the antenna directly up towards the router, I get around 20mbits downstream (using speedtest.net tool from the play store). if i point the antenna in any other direction, it drops to between 3 and 10mbit. (my provider gives me a 40mbit connection which is why i'm doing internet bandwidth tests, since my provider speed is not a bottleneck).
to me the wifi performs well, but it's very directional. I wasted so much time flashing different roms and kernels thinking that my crappy wifi performance was related until i realized that the positioning made all the difference in the world.
forgot to mention i'm using a cx919 and have an external, i think you're using a different stick without an external antenna so forget all this positional stuff that's been affecting me
There are currently 2170 users online. 1 members and 2169 guests.
