I do not own this device. Knowing some things about your device's hardware may help, like WiFi module used, etc. Also quality pictures of the PCB may help others suggest a firmware to try.
Whatever you do, try to get a copy of the firmware that is on it now, before you experiment. There is always risk associated with trying other firmwares, and you will want the original F/W just in case. Though bricking is still possible.
OpenELEC will likely run better and faster than Android will on the S805.
