New Firware: MECOOL BB2 Android 6.0 Amlogic S912 TV BOX
This update is fine. now everything plays (mostly) well. 4K and even HDR is playable.
This issue with not recognizing Wired Ethernet card upon boot is also solved.
Instructions for update:
Download the .ZIp file from: https://mega.nz/#F!3NdEmILC!ASBWA2gg2_ynoflSHt9-uA and put it onto USB stick.
Put the stick into BB2, Go to OTA update program and select local update. You do NOT need to select wipe data or media!
Select the file from USB stick and let it update.
Upon reboot, go to storage/reset from settings, select cache and wipe the cache.
That's all.
Originally posted by bugatsinho View Postkodi still crashes after the update....only if you disable the accelaration of amcodec on kodi video settings it works!But the box is fast...also has many bugs on the homescreen many times apps on favorites are missing nad you have to reboot the box to show them...
Originally posted by tomsag View Post
Seems you have problems with installation. You might factory reset the system to try to solve it (this is from settings).
Originally posted by tomsag View PostI have kodi 17 beta 3 (the original which came with the box) installed and it works (there is no amlogic HW switch). The other one which is installed (a 16.1 fork) works also with amlogic hw enabled (but this one is only for test installed).
There are currently 3992 users online. 0 members and 3992 guests.
