Thanks,
Install apps to NAND flash drive
I just got a new tv stick with 8GB NAND memory. 1GB partition to OS and 7GB for storage. Every time I downloaded an app from Google play store, it stored in the 1GB partition and not the 7GB storage. Any idea how I can redirect to my 7GB free NAND memory storage?
Thanks,Tags: None
Answers
Originally posted by olee View PostI just got a new tv stick with 8GB NAND memory. 1GB partition to OS and 7GB for storage. Every time I downloaded an app from Google play store, it stored in the 1GB partition and not the 7GB storage. Any idea how I can redirect to my 7GB free NAND memory storage?
Thanks,
I checked this forum already and I couldn't find the answer. I know I can use app2SD app to move the apps to my SD card, but I have almost 5GB of empty RAM space that I can store apps so why do I need an External SD card?
I might need a new ROM that will allow my to use this extract partition space that is sitting in the NAND flash.
Thanks.
So any roms for your stick?
Originally posted by olee View PostSorry, my stick is CX-803ii.
Originally posted by peety View PostSorry, I do not have time to look. But are you saying there are no roms available that will partition the space correctly for you? I know with the finless roms for my stick and another. There is a choice available for that when you flash. You may not think you will need an ext. sd card. But Il bet you will change your mind when you start to fill up that space..lol..Anyway have you looked?
Yeah. I saw that the Finless rom from Bob will be able to change the app space from 1GB up to 6GB if needed.
There are currently 2176 users online. 2 members and 2174 guests.
