Plex app problem
Plex app problem
Anyone know a solution for fixing the problem with only some videos playing on the T428? I heard of a possible solution of using a previous version of 2.5.x.x of Plex app to fix the issue. However i don't think the root of the cause is the plex app it is probably some sort of video transcoding issue in the ROM. Is there an alternative ROM anyone recommends or a solution? Running the 1.5A finless rom right now.Tags: None
I run the Plex plug-in on an unRAID server. Your Android device shouldn't have anything to do with the transcoding work cause its all done on the device that is your Plex server. If one video plays they all should. At least that's how I understand it. Have you messed with the quality settings on the Plex server? Like the Local, Remote, and 3g(?) streaming settings?
You may have to change them around due to the T428 WiFi only running at a max of 65Mbps. If your wired with the USB-to-RJ45 that may help a bit maxing out at 100MbpsTV Stick: MK808 // Tronsmart T428
ROM: Finless 1.7c w/Pimp My Rom // Nexus SDK2 Multi-Window v1.2
CPU: @1.6GHz OnDemand Governor NOOP I/O Scheduler
Recovery: ClockworkMod
Kernel: Omegamoon // 1080p OC kernel 720ddr 1.9cpu
Phone: Samsung Galaxy Note II
ROM: Whompasaurus v4.2
Kernel: Persus
Huh. Weird. That's the one I am on. Guess I wont be updating.TV Stick: MK808 // Tronsmart T428
Kernel: Persus
I had same issue and found a way round
Originally posted by relaxed83 View PostAnyone know a solution for fixing the problem with only some videos playing on the T428? I heard of a possible solution of using a previous version of 2.5.x.x of Plex app to fix the issue. However i don't think the root of the cause is the plex app it is probably some sort of video transcoding issue in the ROM. Is there an alternative ROM anyone recommends or a solution? Running the 1.5A finless rom right now.
Plex app from play store (version 3.0.7.0) with tronsmart 4.2 stock rom,finless 1.5 rom and mk 908 rom
Then used amazon app store version of plex (2.5.4.7) everything worked fine until the version was upgraded to 3.0.15.24 .Now the situation is bit different.I had to use external player option to play videos using mxplayer,video app,vlc player etc .Found mx player as best with less heating...
tried new plex app version 3.0.14.23 from google play store but same result.
So now using external player option with imac plex server in local network.
My other plex clients in windows 8 and ipad worked fine with same server throught out this period without an issue
Now using finless 1.5 rom
Hope this helps
There are currently 1564 users online. 0 members and 1564 guests.
