MK908 Stuck Authenticating Wifi
When I first got my 908 Wifi worked fine, it started getting stuck authenticating Wifi when I flashed the finless 1.5 rom. Thought it might just have been the rom, so I flashed to the Tronsmart firmware from 7/4 and the problem is still there. Anyone have any idea's for me? Everything else seems to work fine, tho without wifi I didn't test much. -
Originally posted by David Webb View PostWhen I first got my 908 Wifi worked fine, it started getting stuck authenticating Wifi ...T428 ,Radxa Rock (RR), cs918s v1.0, waiting for my X7...
Originally posted by kjy112 View PostI have the same Wi-Fi issue as well. Does it require N router to work? It seems to disconnect every min.
Wi-Fi b/g is compatible with NT428 ,Radxa Rock (RR), cs918s v1.0, waiting for my X7...
Are you using any wireless mouse/keyboard/combo either 2.4GHz RF or bluetooth-based? If yes, that might be part of the problem. Currently there are issues with MK908 (no idea if any others are affected) where you might experience disruptions especially while using bluetooth and WiFi. Supposedly this was fixed some with the 06/14 tronsmart rom http://blog.geekbuying.com/index.php.../#.Udg9L_msh8F (and you would think that would carry over to the 07/04 tronsmart rom) If you do have wireless devices connecting, try to use a wired mouse or keyboard and test out your AMP and see if the WiFi disruptions continue. If you don't have those kind of devices.. I don't know what to tell you. You might want to try reflash a ROM again and see if you might've just had a bad flash. G'luckQuestion Reality: Find Your Own Truth!
My MK908 Cooling Mod and Breakdown : HERE
My RK3188 Github Repos (NOTE: Works-in-Progress!) : HERE
Sent my Epic4G AND Backflip into nearspace... what have YOU done with your phone?
Want to say thanks for something I did/said or DONATE to my drink fund?
Originally posted by ilan316 View PostColor is grey, but i used 2 different routers.
are both router are defective? while with smartphone they are working with out no problem
I dont think so.T428 ,Radxa Rock (RR), cs918s v1.0, waiting for my X7...
There are currently 2026 users online. 0 members and 2026 guests.
