MK908 Stuck Authenticating Wifi
If you are not familiar with router setting (event if I am familiar I would do it) reset your router and configure your wireless setting with password. Usuly default router setting are for wide use. Also remove the network in mk908 and make a new connection.Last edited by Sarco; 08 July 2013, 17:53.T428 ,Radxa Rock (RR), cs918s v1.0, waiting for my X7...
Router, router...
First your router work with software, that mean that errors are possible. Router always come with a reset button to clean the internal memory. If you work with router you know that. I use to install lot of home network and I want to share some common errors:
1- Password: lot of people confuse password of their computer with the router password
2- Spelling mistake: If you included capital be sure to put them. (some router will connect but will not work)
3- Rember this: if your router is working since a long time, you may have forget some settings you changed. Ex: for better privacy you removed name broadcast ... and now you do not see your network!
4- Power outage could produce corruption not neccessary affecting unless new devices are add or changing settings.
5- WEP authenfication is incompatile with NLast edited by Sarco; 09 July 2013, 13:38.T428 ,Radxa Rock (RR), cs918s v1.0, waiting for my X7...
There are currently 1940 users online. 0 members and 1940 guests.
