[HOW TO RECOVER] So you bricked your box
    calc
    here is all the log that the board says (sorry the late answer)
    TE: 23035
    BL2 Built : 13:48:56, Sep 23 2016.
    gxl g7459bd4 - jianxin.pan@droid06
    set vcck to 1120 mv
    set vddee to 1000 mv
    Board ID = 2
    CPU clk: 1200MHz
    DQS-corr enabled
    DDR scramble enabled
    DDR3 chl: Rank0+1 @ 912MHz - PASS
    Rank0: 1024MB(auto)-2T-13
    Rank1: 1024MB(auto)-2T-13
    DataBus test pass!
    ADDR-W[0x00004000]:0xaaaaaaaa,R:0xf8c185e2
    ADDR3-W[0x00000004]:0x55555555,R:0xa11889ca
    ADDR3-W[0x00000008]:0x55555555,R:0xa11889ca
    ADDR3-W[0x00000010]:0x55555555,R:0xa11889ca
    ADDR3-W[0x00000020]:0x55555555,R:0xa11889ca
    ADDR3-W[0x00000040]:0x55555555,R:0xa11889ca
    ADDR3-W[0x00000080]:0x55555555,R:0xa11889ca
    ADDR3-W[0x00000100]:0x55555555,R:0xa11889ca
    ADDR3-W[0x00000200]:0x55555555,R:0xa11889ca
    ADDR3-W[0x00000400]:0x55555555,R:0xa11889ca
    ADDR3-W[0x00000800]:0x55555555,R:0xa11889ca
    ADDR3-W[0x00001000]:0x55555555,R:0xa11889ca
    ADDR3-W[0x00002000]:0x55555555,R:0xa11889ca
    ADDR2-W[0x00008000]:0x55555555,R:0xa11889ca
    ADDR2-W[0x00010000]:0x55555555,R:0xa11889ca
    ADDR2-W[0x00020000]:0x55555555,R:0xa11889ca
    ADDR2-W[0x00040000]:0x55555555,R:0xa11889ca
    ADDR2-W[0x00080000]:0x55555555,R:0xa11889ca
    ADDR2-W[0x00100000]:0x55555555,R:0xa11889ca
    ADDR2-W[0x00200000]:0x55555555,R:0xa11889ca
    ADDR2-W[0x00400000]:0x55555555,R:0xa11889ca
    ADDR2-W[0x00800000]:0x55555555,R:0xa11889ca
    ADDR2-W[0x01000000]:0x55555555,R:0xa11889ca
    ADDR2-W[0x02000000]:0x55555555,R:0xa11889ca
    ADDR2-W[0x04000000]:0x55555555,R:0xa11889ca
    ADDR2-W[0x08000000]:0x55555555,R:0xa11889ca
    ADDR2-W[0x10000000]:0x55555555,R:0xa11889ca
    ADDR2-W[0x20000000]:0x55555555,R:0xa11889ca
    ADDR2-W[0x40000000]:0x55555555,R:0xa11889ca
    AddrBus test failed!!!
    GXL:BL1:9ac50e:a1974b;FEAT:ADFC318C;POC:3;RCY:0;EM MC:800;NAND:0;READ:0;0.0;CHK:0;
    TE: 23123
      It looks like either the BL2 is corrupt or your hardware might be bad. You should be able to try the eMMC pin short method to force a boot off of sdcard and reinstall the firmware and see if that fixes the problem.
        Do you know how to do the pin short method on the "sdtnrgama-008g" chip?
        Thanks in advance
          I wasn't able to find a datasheet on it, what does the chip itself look like, can you post a picture of it? Hopefully its a TSOP instead of a BGA chip.
          If it looks like the picture on page 13-14 of the following document then you can short a few of the i/o pins with a flat blade screwdriver (very carefully), while you plug in the board. It should then show something like the following while attempting to boot, note the SD in the line. If you do that while having a sdcard inserted in the system it should attempt to boot off of it. You can remove the tip of the screwdriver once it starts to boot off SD.
          WARNING shorting the wrong pins probably can burn out the eMMC be sure to only short i/o pins.
          Code:
          GXM:BL1:dc8b51:76f1a5;FEAT:ADFC318C:0;POC:3;RCY:0; EMMC:0;READ:0;CHK:AA;SD:0;READ:0;CHK:AA;USB:8;
          http://www.onfi.org/~/media/onfi/spe...i_2_0_gold.pdf
            i short the 31 and 32 pins and i get the following
            GXL:BL1:9ac50e:a1974b;FEAT:ADFC318C;POC:3;RCY:0;EM MC:800;NAND:82;SD:0;READ:0;0.0 ;CHK:0;
            no sdio debug board detected
            TE: 195826
            set vdd cpu_a to 1120 mv
            set vdd cpu_b to 1050 mv
            Board ID = 2
            CPU clk: 1200MHz
            DQS-corr enabled
            DataBus test pass!
            pd: i unshort and the log reverses to the initial output
            PD2: like this is a loop i don't know what's the begining
              So it looks like it is booting off the sd card but that it has the same build version of BL2 and is giving the same error.
              What happened to cause the bricking?
                i tried to flash a custom rom via recovery (not twrp)
                so, i have to change the bl2?
                  Do you have the stock firmware and u-boot on the sd card? As described in the first comment on the thread.
                    not really, i can't find the exact firmware for this board
                    first i use the files from this firmware
                    now i use the files to try to boot a linux with the multiboot uboot
                    i use the file "S905X_Linux_console_2GB_20161010.img" and i get the following output
                    Code:
                    GXL:BL1:9ac50e:a1974b;FEAT:ADFC318C;POC:3;RCY:0;EMMC:800;NAND:82;SD:0;READ:0;CHK:AA;USB:8;LOOP:1;EMMC:800;NAND:82;SD:0;READ:0;CHK:AA;USB:8;LOOP:2;EMMC:800;NAND:82;SD:0;READ:0;CHK:AA;USB:8;LOOP:3;EMMC:800;NAND:82;SD:0;READ:0;CHK:AA;USB:8;
                    i guess that is a advance... not?
                      That looks like its now not even seeing the BL2 on the sd card anymore, heh.
                      Which box do you have? If you aren't sure then a high resolution photo of the board will probably help.
                      BTW - Using a firmware that is not for your board will most likely brick it. The kernel (and I think uboot) needs to have the proper device tree file for the board it is running on.
                      This gives a brief overview of what that is:
                      https://events.linuxfoundation.org/s...ee-dummies.pdf
                        sorry for the delay, i'm reinstalling the SO on my computer and i have some troubles with the HDD :C
                        there is a set of photos, hope that can be usefull
                          It looks like it is probably this one:
                            i downloaded the firmware from here, but, it's not a img pure file...
                            anyway i try to boot using the recovery.img that comes with it, and there is the log.
                            Code:
                            GXL:BL1:9ac50e:a1974b;FEAT:ADFC318C;POC:3;RCY:0;EMMC:800;NAND:82;SD:0;READ:0;0.0;CHK:0;
                            TE: 196275
                            set vcck to 1120 mv
                            Board ID = 2
                            CPU clk: 1200MHz
                            DQS-corr enabled
                            DDR3 chl: Rank0+1 @ 720MHz - PASS
                            Rank0: 512MB-2T-11
                            Rank1: 512MB-2T-11
                            DataBus test pass!
                              ADDR-W[0x00004000]:0xaaaaaaaa,R:0x28a921f9
                              ADDR2-W[0x00008000]:0x55555555,R:0x5e5d761c
                              ADDR3-W[0x00008000]:0x55555555,R:0x55555555
                              ADDR2-W[0x00010000]:0x55555555,R:0x5ee77635
                              ADDR3-W[0x00010000]:0x55555555,R:0x55555555
                              ADDR2-W[0x00020000]:0x55555555,R:0x5ee77635
                              ADDR3-W[0x00020000]:0x55555555,R:0x55555555
                              ADDR2-W[0x00040000]:0x55555555,R:0x5ee77635
                              ADDR3-W[0x00040000]:0x55555555,R:0x55555555
                              ADDR2-W[0x00080000]:0x55555555,R:0x5ee77635
                              ADDR3-W[0x00080000]:0x55555555,R:0x55555555
                              ADDR2-W[0x00100000]:0x55555555,R:0x5ee77635
                              ADDR3-W[0x00100000]:0x55555555,R:0x55555555
                              ADDR2-W[0x00200000]:0x55555555,R:0x5ee77635
                              ADDR3-W[0x00200000]:0x55555555,R:0x55555555
                              ADDR2-W[0x00400000]:0x55555555,R:0x5ee77635
                              ADDR3-W[0x00400000]:0x55555555,R:0x55555555
                              ADDR2-W[0x00800000]:0x55555555,R:0x5ee77635
                              ADDR3-W[0x00800000]:0x55555555,R:0x55555555
                              ADDR2-W[0x01000000]:0x55555555,R:0x5ee77635
                              ADDR3-W[0x01000000]:0x55555555,R:0x55555555
                              ADDR2-W[0x02000000]:0x55555555,R:0x5ee77635
                              ADDR3-W[0x02000000]:0x55555555,R:0x55555555
                              ADDR2-W[0x04000000]:0x55555555,R:0x5ee77635
                              ADDR3-W[0x04000000]:0x55555555,R:0x55555555
                              ADDR2-W[0x08000000]:0x55555555,R:0x5ee77635
                              ADDR3-W[0x08000000]:0x55555555,R:0x55555555
                              ADDR2-W[0x10000000]:0x55555555,R:0x5ee77635
                              ADDR3-W[0x10000000]:0x55555555,R:0x55555555
                              ADDR2-W[0x20000000]:0x55555555,R:0x5ee77635
                              ADDR3-W[0x20000000]:0x55555555,R:0x55555555
                            TE: 196276
                              Are you sure you are using the u-boot from the package as the log appears to show it is the same version you were booting before.
                              Code:
                                form the zip package?
                                i 'm quite lost form here D:
